Do I need chains?
/ Do I need chains? #21
I started to make a set of chains for my BX25D last year but ended up purchasing them. It was just taking waaaay to long to fabricate them. They worked great with the R4 tires and I'm waiting delivery of a set for the front. I have 2" spacers on the back but I think I can use the front chains without them. It's getting too icy around here this year to be able to plow without the front chains. My GMC has 4 studded tires so it will move around OK, but the BX is great for getting into those places that the truck can't...like plowing the path for the oil man. I put a 2 1/2" split pipe on the front edge of the FEL bucket to prevent digging up soft ground and that works great! I also have a home made back blade that scrapes snow pretty well after the ground is frozen. Will post pictures when I get the chains on.
Can you please post a picture of you 2 1/2" split pipe you use. I'm curious.
Thanks
/ Do I need chains? #22
If you have a very steep driveway you may want chains. I have had a slightly sloped drive ( Big Dip in the middle of my drive) and when ever i was coming up out of the dip traction became an issue when pushing deep snow. If your drive is fairly flat, I agree with the guys who say to try without them.
/ Do I need chains? #23
Thanks
Here you go! I just drew a straight line down the length, took the sawzall to it, then just get a BFH and pound it onto the edge of the bucket!
/ Do I need chains? #25
Your a genius - who would have thought of that? :cool::D and I even happen to have a chunk available. :thumbsup:
Sorry but I can't take credit for the idea...saw it on TV when some little league team used PVC on plows mounted on ATVs to clear a ball field. Look on GOOGLE and you will see lots of other applications. Some people add some brackets to hold it on but it's pretty tight on mine. If it loosens, then I'll add some angle iron on the ends such that they can be bolted to the bucket. Have fun!
/ Do I need chains?
Just to report....we got our first winery mess last weekend. ~1 -1.5" of sleety hard packed snow. The tractor did great without chains and just weight on the hitch. Now I need to do the lazy man's upgrade. I still have on the mowing deck but the 62" deck is wider than the 54" blade. Time to fab up some wing extensions to get the width standardized; I know this sound crazy but I hope to not even need to drop the mowing deck in the winter. Heck I could even mow with the blade on the front....but that at least is a easy quick attached to remove.
/ Do I need chains? #27
I saw you should get a set of chains. If you get some ice under the snow you will want them. Chains are really cheap for your tire size anyway. I say it is better to have them and not need them than to need them and not have them.
/ Do I need chains? #28
My neighbor tried that with his DEERE last year and ground clearance became an issue in the deep snow we received.
/ Do I need chains? #29
I suppose it depends what type of terrain you are plowing. I attempted to plow a hilly gravel laneway with my B26 and it was a horrible experience. There are a few spots with a hard bank that had the tractor slipping sideways. I went out and bought chains (which then required wheel spacers). More money than I wanted to spend later I'm content with the setup.
/ Do I need chains? #30
Turfs here plowing since 1999 with no extra weight or ballast. Most of the time I'm in 2wd unless it is a heavier snow or I'm going into the ditch.
/ Do I need chains? #31
I need chains when my gravel drive is icy. I use my bucket to clear and push snow. Mostly flat driveway. We always have icy days in Maine- so the chains go on and stay on until spring. Not on yet, waiting for a warm day!
/ Do I need chains? #32
I bought chains a couple of years ago for my current tractor, There are just times you cannot get up the hill, let alone plow anything. One day I took the tractor out of the "kioti den" and just sitting still the tractor started to drift down the hill and would have went over the edge If I didn't use the bucket to save it and get it back to the barn. I was glad I got it back inside finely and went in and ordered the chains. They make all the difference in the world. Some years we don't have enough snow and ice to worry about, and other years we have a huge mess on our road. The ice and ice pellets that freeze into solid ice are the worst. If we had flat ground, which we don't, and mostly just snow, I wouldn't bother with them, but as is I have to have them.
/ Do I need chains? #33
Do I need chains?
Do we really need seat heaters? No, but they sure make your life a bit nicer! My turf tires will normally do the job just fine, but boy do they make it nice when the snow is over a foot. Doesn't slip all that much without, but doesn't slip at all with them, and will push up much larger piles of snow.
I have not found any real marking on asphalt from them that doesn't disappear, and all my neighbors have asphalt driveways. So far, at least, no complaints, just thanks for clearing snow. Guess I'm lucky.
I also advocate for tirechains.com they've been really good to me and seem quite reasonable. They have some pretty good installation videos as well.
George
/ Do I need chains? #34
I think I am going to invest in a set for the rear of my girl. When the snow is wet and sloppy, then I slide around a bit with my R4's. I think a set of V-bars will solve that problem.
/ Do I need chains? #35
James - true story......unfortunately, but that which doesn't kill us, makes us stronger, and hopefully smarter!
I worked at a large prison. One of my duties was to push coal into the hopper of our boiler house. We used a 750 Case front end loader, 1964 model. That was the pre ROPS days, and no seat belt either. Made for safer operators because you did not want to die!
When it snowed, I would take the Case and clear the roads around the institution. made it nicer for everyone, didn't take me long, and built up a lot of good will.
We got about 1/4" of ice one night, followed by about 4" of snow. The shops area was down a hill from our shop so I turn down to clean up that area first as the inmate staff was about to come down, and the shop guys would be wanting to drive down shortly.
It went bad from the top of the hill, the machine started forward all by itself. I shove the bucket down.....yeah, THAT oughta do it. It flipped the machine around and we started doing 360 degree doughnuts down the hill. Remember, no ROPS, no seatbelt. At the bottom of the hill is a 10' area of grass, then 3 rolls of razor wire (Maximum security style) then a 10' high fence, interstitial area with more razor wire and another fence.
No manipulation of the bucket helped, I'm not even THINKING of leaving the machine, so I just hunker down and said "Man, this is gonna hurt"!
Thankfully, the grass area bit into the tracks. When I stopped, and subsequently opened my eyes, I could reach out and touch the razor wire! And to make it REAL nice, I could see a tower officer aiming at me, he thought it may be an escape attempt! Nice, if the wire hadn't eaten me alive, my prize was going to be a bullet.
Yes, machines do, in fact, move by themselves! I ordered 3 inmates to help me remove the seat from a strangely dark and remote area!!
George AF4JH
/ Do I need chains? #36
George AF4JH
George, I will have to admit your story is quite a bit better than mine!. My tractor just started to slip sideways on the ice by itself after I got it out of the barn, and I was able to stop if fairly easily with the bucket edge. I did mess around with it another 10 minutes to get it back into the barn though. It was not that easy. No razor wire or threat of getting shot here though! .:shocked: 73 de K0UA
/ Do I need chains? #37
That is cool, I did the same to my landscape rake with a heavy duty pvc p1121161558a.jpgipe.
/ Do I need chains? #38
That is cool, I did the same to my landscape rake with a heavy duty pvc pView attachment 492837ipe.
I started out using the PVC but when it's below 32 deg. it tends to break. But it worked fine until I hit some really hard ground/pavement. :eek:The PVC was not strong enough to stay on when I back dragged as well. That pipe's not moving! :thumbsup:
/ Do I need chains?
I am not sure if I should be happy or not but we finally got snow! The best part of having a tractor with a plow or blower is knowing you have it, but not needing to use it.
Just to update after a 17" snow storm I am convinced for my needs I do not need chains in my application. The other than putting the plow on the tractor all I did was add ~250 lbs of weight on the hitch. I was able to plow up grade in high gear as long as I had momentum.
/ Do I need chains? #40
George AF4JH
That even sound more interesting than my steel tracked excavator "ride' down any icy dirt road.
http://www.tractorbynet.com/forums/snow-removal/374534-how-steer-tractor-r4s-snow.html
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2014 FREIGHTLINER CASCADIA SLEEPER (A59904)
2014 FREIGHTLINER...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
