Will this be tomorrow's transportation?
Status
Not open for further replies.
/ Will this be tomorrow's transportation? #121
Liquid energy transport will continue to be the king cause its the most economic over all. Until there's something cheaper that also covers the switching cost, we'll stay on liquids. Sadly enough it usually takes a significant event to switch. Cars, refrigeration, airplanes, typewriters, printed books, buggy whips, read the machine the changed the world. These things have a cycle. While combustion engines have a pollution issue and will never be really efficient compared to other forms of propelling a vehicle, they are currently the best answer anyone has come up with. I think the revolutionary event that kills the car isn't a fuel or energy solution or even a better car; it will be something very different that no one was expecting.
/ Will this be tomorrow's transportation? #123
Yes but as of today there's no real, large scale infrastructure for it, even in liquid form. Theres not a mass way to move, store it or even get it to point of sale. WHile it may be a great fuel, its more expensive per overall mile than petroleum products. By overall miles not those in the car, those to get it from production to use.
/ Will this be tomorrow's transportation? #124
If the car can make 200 miles/charge it will work for me. Our round trip to the town is about 100-120 miles three times a week. So green or not green it makes financial sense for us.
They're just around the corner. I do a 300mi round-trip about once a week(just got back today a few hours ago). Needed ~30% to make the last 1/3 of my leg so I popped in the supercharger. By the time I could use the local restroom I had a enough to make it back. This is in freezing temperatures, if it's warmer out I usually don't need to stop.
As battery prices start taking on proper economy of scale you'll start seeing more cars in the ~30k range that'll do what you need.
/ Will this be tomorrow's transportation? #125
I did simple estimation of the break even point. If I buy Cruze for 18000 or Bolt for 30000. Assuming 1200 miles /month. Depending on cost of gas it will take anywhere between 10 years at 2.50/gal to 5 years at 5 gal. But if I decide to buy gasoline car I would most likely spend about 25000. And that lovers the break even point to about 2.5 years at 2.5/gal. I know 25000 buys better car but that make only little difference to me. Any new car will be step up from what I drive now.
I would predict that that electric cars will gain popularity in near future.
1.) They are fun to drive.
2.) They are quiet.
3.) They cost about 3 to 4 times less to operate.
It is true there is still oil in ground but there is no cheap oil in ground.
I am currently working at oil production facility. The wells are about 20 years in operation and are significantly depleted. What comes from ground is 80% water and 20% oil. The water was pumped under ground to increase pressure of oil to push it to the surface. So it cost more to process the oil (separate water and gas) and in the same time there is less coming out. In other words large investment had to be made (hundreds of million of dollars) to add pumps and compressors to get less oil than when the oil wells were new. I do lot of work for oil and gas all over the world and I see the same story everywhere.
Infrastructure can be developed can it not? There originally was no gasoline infa structure. Diesel used to be limited to many fewer locations.
/ Will this be tomorrow's transportation? #128
Yeah and I think that will be Thorium fueled fission reactors, likely the molten salt type. With enough cheap and clean energy on tap, you can make a lot of stuff start to make sense. And this seems to be the most likely with few or the drawbacks present in today's light water uranium fueled reactors. But just uttering nuclear is a lot like shouting boogeyman to those who simply don't want to understand. And this is a technology that could even help eliminate much of the radioactive crap that we're currently stuck with. Instead of stockpiling it for a gazillion years, you can burn it up and use it to make power. Even the plutonium from nuclear weapons and be disposed of. Remember all we're trying to do is make heat to boil water and make steam so in addition to building more power plants, you could conceivably convert every power plant today to use a thorium fueled reactor as the heat source and do it safely.
Thorium Fuel Cycle - IAEA NEFW
/ Will this be tomorrow's transportation? #129
Correct and before anyone can say it, gasoline is very volatile too but we got around it somehow.
/ Will this be tomorrow's transportation? #131
2.) They are quiet.
One wrinkle in your plan is the elimination of idiotic gubberment subsidies. Not exactly a remote prospect given the last election.
Bear in mind that with the present state of the grid, we can't even satisfy 100% of the demand on a hot day. What happens if all of a sudden everyone is plugging a car into the grid? Is the tooth fairy gonna come to the rescue?
/ Will this be tomorrow's transportation? #132
At a huge cost in compression, cryogenics, storing and transport.
Well it ain't exactly easy to produce, transport and dispense gasoline either but we manage to do it in multiple flavors and grades. All of those problems are not really problems, they are simple engineering exercises. The biggest problem with hydrogen is where it comes from. Today that's right back at the oil well but with enough electricity from nuclear it could be done. A lot of things could be done including solving a lot of water shortage issues. The big nut to crack in a many problems is the energy nut. Crack that nut and all of a sudden you find economical solutions to lots of problems. With enough cheap electricity on tap you could even make your own hydrogen fuel from your garden hose. BTW They have hydrogen fuel stations in place in Iceland. The first went into operation in 2003 I think it was. The hydrogen is produced with electrolysis because Iceland has a heapin helpin of geothermal on tap.
/ Will this be tomorrow's transportation? #133
Freight traines could beat or equal that speed while caryying 10x as much. Okay, the 10x may be a bit much but...
10X is a vast understatement. Coal trains typically weigh 15,000 to 20,000 tons, 100 times what the airship would carry. Our rail system continues to be underused and poorly maintained and planned.
/ Will this be tomorrow's transportation? #134
Will the transporting industry be converted?
The technology seems to look Good.:)
[video]https://electrek.co/2016/07/20/tesla-semi-truck-business-cargo/[/video]
Great topic Egon!
This is really fascinating isn't it?
/ Will this be tomorrow's transportation? #135
If what you say will happen then electric cars will become mainstream. Hydrocarbons will be used to make something more useful than fuel.
/ Will this be tomorrow's transportation? #138
Hydrogen distribution would have to build its infrastructure over time, like the cel networks did with placing towers one by one. They'll have to compete with dino fuels for quite some time, and it'll surely take a while for gas and diesel vehicles to be emission tested off the roads altogether.
We're not all being closed-minded about green technology, but subsidies seem necessary until economy of scale can provide profit margins to those in the biz big time. Remember that just because a company is involved in 'green technology' doesn't mean it's a good investment. Some will fail despite the growing fervor and gov't help. ("Solyndra, report!")
As long as operating cost favors ICE over electric or hybrid options by a large enough margin a lot of us still won't 'pay the freight' just to 'go green'. I'm sure many of us will also die waiting for a pickup that will tow squat vs a puny commuter 'beer can' that's far from living up to our 'manly' demands. :D (Just sayin' ...)
Great topic Egon!
Hi Rox.
What will happen and what is possible is always interesting.
Even more interesting is the introduction of a new sceince displaceing what's in place now. As an example the introduction of the automobile met with considerable resistance from some.
The current California Hydrogen vehicle infrastructure looks promising.
European use of wind and solar also get my attention. Just wish there were reliable sources of the cost parameters.
Status
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
1988 Jeep Wrangler Sahara (A64119)
1988 Jeep Wrangler...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
1069 (A64280)
1069 (A64280)
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
