Hydrualic problem with XG 3025
/ Hydrualic problem with XG 3025 #1
hturner12
Gold Member
Thomaston ga
LS Xg 3025
I had a leak at the red banjo fitting on the bucket control. I tightened it up. I checked fluid and it was low. Got some fluid yesterday fill it back up. Now have 2 small problems .
1. Bucket will not go into float. All other buck controls are fine.
2. When I push the left brake pedal the red brake light on the dash comes on and that pedal does not always come all the way back up
/ Hydrualic problem with XG 3025 #2
Does the lever for the bucket go all the way up?
And if it does, does it feel normal?
Just off the top of my head I am wondering if a metal shaving or trash of some kind is binding it or if it's bleed through of some kind due to the valve in the control.
It feels like it goes al the way up. It worked prior to the small leak. The leak was just a loose fitting. When I order my filters for the 50 hour I am going to ask the dealer about it and the brake pedal issue
/ Hydrualic problem with XG 3025 #4
I've got a xr4046h and I ran into the same issue with my bucket float (or lack of) when I did my 50 hour service. It hasn't been a major issue for me at the moment, so I haven't tried to track it down (been busy with the holidays too). Keep us posted.
update I pulled the red line off the control valve was going to replace the crush washers. They are not normal crush washers. They hyd shop said they were British. In the parts manual for the loader it call the a 3/8 bond seal. It is 3/8 ID. Put it back together. I called my dealer to warranty them since the fitting came loose. Still waiting for them. After I put the hose back on made sure it was tight, float started working agin. Do not know what I did.
159118 (A60430)
159118 (A60430)
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
