Chinese 16HP vertical shaft engine problems
/ Chinese 16HP vertical shaft engine problems #1
Wazrus
Member
Sydney, NSW., Australia
Iseki TF 317; Honda harmony, Toyota SDK7 skid steer
My Chinese 16HP vertical shaft ride-on engine has been running well since it was installed about four years ago. I think the brand is Loncin. Recently it began 'surging', in that the RPM would fluctuate almost from idle to max RPM, or so it seemed. Eventually, after a relatively short time, the engine would simply stop. Now this said CARBURETION in capital letters, or at least fuel supply problems. I might mention that I could see the governor linkage moving as the engine surged. I replaced the carburettor, air cleaner, in-line petrol filter and the vacuum petrol pump. The engine started quite easily, as it has always done, before parts were replaced and even after a surging bout and a stop. I did note, though, that it would not start from quite warm without choke; I would expect a warm engine to start with at least a little throttle, but even with a lot of throttle, there was no start. It 'liked' its dose of choke!
So after the carby, air cleaner, filter and pump were replaced with new parts, the engine again started quite well - first crank of the starter, with choke - it ran quite well and I was able to mow effectively for the next fifteen minutes, then it simply died once again! No surging this time, it just croaked! By the way, I also replaced the spark plug. It still starts readily, but only with choke, even when warm.
By a process of elimination, I reckon it's pretty safe to say that the fuel system isn't the culprit. As I said, then engine is about four years old and it hasn't done all that many hours.
Any suggestions, other than a new motor, from the membership?
Thanks
Wazrus Sydney, Australia
Perhaps a coil getting weak?
Thanks for coming back, KC. The coil was my next bit to replace: I think it's perhaps the only bit left! I had also considered a faulty oil level switch/sensor. I have made sure that the oil level is good. Might the diode/charging rectifier be a candidate, too, d'you think?
Wazrus
/ Chinese 16HP vertical shaft engine problems #4
I have found the carb on these engines to often be the problem.
These service bulletins from Champion Generators which use carbs like your engine would have show some jets which need to be cleaned by hand and not rely on soaking or spray cleaners to get the small passages clean.
http://www.championpowerequipment.com/media/3465/cpetb2050016-cleaning-the-pilot-jet-196cc-439cc.pdf
http://www.championpowerequipment.com/media/2052/cpetb2050018-altitude-jet-installation.pdf
Removing the main jet to get access to the emulsion tube identified as "A" requires you have exactly the correct screw driver or you will destroy the screw driver slot on the brass main jet.
I find having a set of screw driver tips as would come with a cheap screw driver where you can swap tips often gives you a large flat tip that just fits the slot in the jet. Dont even think of trying to turn it if the bit is not a tight fit.
It is not the charging system!!! Big clue is the need to use the choke. Fuel passages in the carb jets are partially blocked.
Dave M7040
/ Chinese 16HP vertical shaft engine problems #5
I love a puzzle, turning on the choke would also cover up a intake leak, the vacuum would increase when closing the choke butterfly. You never mentioned the electric fuel solenoid on the bottom of the carb,did it come new with the new carb ? maybe it is starting to go bad. You might remove it and bench exercise it , see if with time it starts crawling back out and is leaning out the fuel delivery. It is a electromagnetic , when it cools down it starts working again. Using the propane around the air cleaner would tell you if it is electrical or fuel, but if it was a intake leak it would also cover it up by correcting the air fuel ratio .
/ Chinese 16HP vertical shaft engine problems #6
On an antique tractor ;) my bets would still be on fuel.
Good luck.
Good luck.
Thanks to Dave, Rocky and Sound Guy.
You'd think that a brand new carb would have the engine up and away! I will strip it off -again - and give it a good once-over, as per the Champion links Dave sent and have a closer look at the carb-to-cylinder gasket. The gasket did seem to be of pretty hard stuff, so maybe there's chip out of the sealing face. For Rocky: the engine is probably an older model or something like that and it doesn't have a fuel cut-off solenoid, so that's one part that isn't going to go wrong! When I bought the new carb in Australia, I did notice many, many carbs on EBay, which seemed to be pretty much the same, except that most had the fuel cut-off solenoid, or fittings for it. I was a bit lucky in that I was able to source the exact replacement carb from a firm in Western Australia. I have had the main jet out, with no issues at all. I happened to have a really good fitting screw driver and the jet and tube came out easily.
I will post the results of the fiddling about in the next few days, but any further suggestions anybody has would be appreciated.
By the way, too I do note that the quoted engine capacity is 452cc, which is a bit different from the capacities Champion quote.
Thanks and regards
Wazrus
/ Chinese 16HP vertical shaft engine problems #8
The idea of the fuel solenoid was to stop the engine from back firing when it is shut off. With time the top of the piston and cylinder head builds up with carbon and will get red hot like a glow plug in a diesel engine, when the key is shut off the piston continues to spin a few more turns and sucks in more gas /air mix and is ignited by the red hot carbon and fires when ever it wants and can break the connecting rod.So they put the fuel solenoid on it, probably more worried about warranty work then anything else cause that part is a ton of money. Idling the engine down and let it cool a bit before turning the key off works just as well.
Moving on to another thought, by chance is your fuel tank cap vent plugged up causing a vacuum in the tank? Is your gas tank under the seat ? or under the hood/ bonnet ?
Some engines have a black plastic spacer between the engine and carb and take a gasket on both sides of it. It is hard and brittle . This is where I drill my hole to tap threads for a hose barb to pick up the vacuum for my propane regulators safety device , I have used JB Weld to repair the ones I have broken.
/ Chinese 16HP vertical shaft engine problems #9
Can you hear the solenoid click into the on position when you turn the key on. If not, do you have 12 v to the solenoid. Also make sure the solenoid has a good ground.
/ Chinese 16HP vertical shaft engine problems #10
I'm with Soundguy. Sounds like a fuel supply problem. Did you clean out the fuel tank when you changed the carb? There may be a screen in the outlet of the tank that's clogged.
/ Chinese 16HP vertical shaft engine problems #11
Rocky I agree with your comments on the need for a fuel cut off solenoid but would like to suggest a second reason.
Cheap generators have no idle feature on them as an expensive Honda would that would idle the engine after it warms up and then kick it up to 3600 rpm when there is a call for power. This is done to reduce noise level and save fuel.
On the cheap generator, the carb does not have an idle circuit and when it runs it is at full speed. Getting the engine to stop from full throttle without a lot of run on and back firing is easily accomplished with the solenoid valve on the bottom of the float bowl.
I dont know if the garden tractor carbs with a solenoid are open or closed without power applied.
On generators, which do not have a battery, the solenoid only works while the generator is putting out power. A small amount of DC is taken from the generator to activate the solenoid which cuts off the fuel to the main jet and stop the engine.
Dave M7040
Thanks once again for all your replies. The fuel tank is - or was - under the bonnet. I 'lost' the bonnet years ago, as the new engine didn't quite fit, widthwise, but the hole centres were OK. Appearance hasn't been a priority. Your American engines all sound as though they have a fuel solenoid: the Australian version, or at least my engine, doesn't have a fuel solenoid at all and no, I didn't 'lose' it!
I checked the fuel cap and the tank venting and although there was some crap around the venting arrangement, it didn't seem to affect the problem. I tried running with the cap loosened also, to no effect. I note remarks about the hard plastic 'spacer' between the carb and the cylinder and the gaskets either side of it. I'll be looking at those, too.
Wazrus
Wazrus
Wazrus here again: 8th December, 2016
Today, I stripped the fuel tank out and guess what? The very small strainer located inside the fuel delivery tube was full of crud! Did I hear you say 'no surprises there'? So the new carb, air cleaner, line filter and spark plug were all a bit unnecessary. I can, however, say with a deal of confidence that the engine will be good for at least another four or so years and I'll know where to look next time!
The machine did an hours' mowing without missing a beat yesterday morning. You beaut!
Thanks once again for your help.
Wazrus
/ Chinese 16HP vertical shaft engine problems #14
Another mystery solved , I have had good luck with the Clone engines from china, I have noticed I have to be right on the adjustment of the exhaust valve for a easy spin start, if the adjustment gets a little loose it acts like a low battery, the compression release works well so it must be the electric starters are not over powered,I have looked inside of one of them and it was all metal ,dont see that much anymore .
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
King Kutter 5' 3-Pt Gear Driven Rotary Tiller (A66285)
King Kutter 5'...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
