loose altermnator belt causing many issues, yes ??
/ loose altermnator belt causing many issues, yes ?? #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to All,
Have a 95-96 M5400S w front-end-loader and have issues as of today.
When I started her up, I turned the key to the left to warm-up the glow plugs as I've being doing for the last 20 yrs. But when I did, she started up. That was the first time that ever happened. I was in a hurry to get a stuck tractor out of the mud, and later noticed that the belt was making a squealing noise.
In the next 1 to 1.5 hrs, she would only start If I turned her to the left, and turning her to the far right made either a clicking sound and would not start, except 1-2 times it did start. But turning to the left she started every time, and the belt to the alternative and fan was continuing to squeal.
lastly, the gear shifter both the R, F-hi and F-low, as well as the 1-4 stick shift was real sensitive. Mainly when starting up and getting her in initial gear, they made a quick grinding sound. This too has never happened before either.
Questions:
1. Is the loose belt causing all these strange starter electrical issues? I did not have a lot of time trouble-shoot, but the belt did feel loose.
2. Does the loose belt have anything to do with the gears being hyper sensitive?
3. Is it complicated to install a new belt, or is there anything I need to check that would or could have caused the belt to loosen?
Again, this starting issue has never occurred before and neither has the belt ever squealed before so I am assuming there is a correlation.
Lastly, if I need to do anything to check the belt or other, pls let me know. I will go back out tomorrow and get the ball rolling.
Finally, we had one of our best cold/cool fronts this year as of today, and I replaced 3 of the 4 frt-end-loader cylinders about 3-4 months ago, but did refill w hydraulic fluid. could the cooler weather cause the gear sensitivity? I also checked the battery and neither of the terminals had any oxidation/corrosion or other. Battery was replaced about 2 - 2.5 yrs ago. Have done nothing to drain the battery.
Thank you very much and pls advise, tstex
/ loose altermnator belt causing many issues, yes ?? #2
So, you are saying that the normal GP position actually started the engine, instead of just activating the GPs? Did I understand that correctly?
No, you've got other weird things going on. I'm not saying the loose belt is not a problem, but there are too many things going on that are not related.
I can't see how, but then, I don't know your tractor, and I'm new to tractors in general, so I'll leave that question for those with more experience.
Nah, it's not difficult. But you may not need a new one. They do get slack, and do eventually need to be replaced, but you can nomrally adjust them a few times before that's required. Your owner's manual should tell you how to adjust it. Be careful not to get the belt TOO tight, as this puts too much strain on the alternator bearings and causes premature failure. By "premature", I don't mean that it will fail in a day or two, but that it will fail a lot sooner than it should. For example, if the alternator might have lasted 5 years with proper tension, you might get 2 or 3 years instead.
Yes, the squealing is likely from the belt, but why is the belt loose? Check into that. Correlation is not causation, and coincidence does happen. It should never be assumed, but it should never be ruled out, either.
/ loose altermnator belt causing many issues, yes ?? #3
If you have been running that tractor for 20 years have you changed the belt before?
How many hours on the tractor?
So, you are saying that the normal GP position actually started the engine, instead of just activating the GPs? Did I understand that correctly? Yes. To normally start the tractor, I always turn to the left first to get the GP going, but to my immediate surprise, she just started.
Nah, it's not difficult. But you may not need a new one. They do get slack, and do eventually need to be replaced, but you can nomrally adjust them a few times before that's required. Your owner's manual should tell you how to adjust it. Be careful not to get the belt TOO tight, as this puts too much strain on the alternator bearings and causes premature failure. By "premature", I don't mean that it will fail in a day or two, but that it will fail a lot sooner than it should. For example, if the alternator might have lasted 5 years with proper tension, you might get 2 or 3 years instead. Since the tractor us about 20 yrs old, never changed the belt or alternator, or anything else except the battery, hydraulic hoses, hydraulic seals in cylinder, then the normal fluid changes...maybe I need a new belt anyway or it would not hurt to change it.
will check
I have owned the tractor since new...No, I have never changed the belt bc there has never been a need, until now. The tractor has about 715-730 hrs...as you can tell, I am a weekend farmer.
Thanks for everyone's help and comments - tstex
OK, I found the on-line Op's Manual for the M5400S, and it says to loosen the two alternator bolts and w a lever, pull the alternator until the belt is w /in the acceptable range .28inches to .34 inches. That's about a 1/4" to 1/3" delta. Where do I test this? is it in the middle of the longest stretch of the belt?
when they refer to a lever, is there a specific tool for this? if so, what, or what is the most common tool used for this?
Finally, what are all of the pulleys that the belt resides? It is the engine, fan and alternator? is there also a dummy pulley? I am not at my tractor and the diagram on page 52 to the manual is really a poor picture.
I have not adjusted this belt before, obviously, so any and all help would really be appreciated.
Regards,
tstex
/ loose altermnator belt causing many issues, yes ?? #7
crow bar
Guys,
Just spoke to Kubota Service Mgr. He said that even if the belt is loose, it should not have any bearing on the switch and its functions. When I previously for the last 20 yrs turn the key to the left re the glow-plug, but now it starts that way, said that some type of rodent may have chewed the wires and it has crossed wires or the contacts on the switch are bad...I keep the tractor in the shed [no rodent proof], and have had issues w rodents before.
Wanted to get your opinion on this matter...Thx b-bubba on the lever suggestion
/ loose altermnator belt causing many issues, yes ?? #9
That's exactly right. If the switch is operating differently than normal, that's NOT a belt issue. Could be chewed wires, could be the switch went bad. Some noggin-pokin' is in order, to see if the wiring is chawed.
Thanks Temp.
I agree on checking w lines to see if they are all ok. Once I've gone from one end to the other on the M5400 [BTW, are the wires really hidden anywhere and if so, any tricks on getting to them?] wiring harness and no bites, then I'm going to replace the switch, replace the belt and then for good measures, check the clutch tolerance per spec's.
if anyone has any first hand experience on removing and reinstalling this switch, I am all ears...I know from experience that knowing the special maneuvers on things like this means the difference btw 15 minutes and 1.5hrs. I once watched a guy remove the fuel line from my Stihl 029 and he did it in about 90 seconds...took me near 25 minutes on another one...so, that's why I'm not going to reinvent the wheel anytime soon - thanks gentlemen
/ loose altermnator belt causing many issues, yes ?? #11
If it's chewed, it will be in an accessible area, most likely. I suggest you start with a good visual inspection of what you can see (a telescoping inspection mirror is your friend!), without spending hours on it.
Other than that, time to get busy with a wiring diagram and a meter. Start by testing the switch itself, because, if you don't see any obviously chewed wires, it's likely that the switch is toast. Just take your time, and before you start, get some paper and write out the tests you are going to perform. For example, if the switch has, let's say, 5 wires coming off of it, and the wiring diagram tells you that in position 1, you should not have any connectivity between any of them, and nothing going to ground, you will have these tests to do:
Orange to Green
Orange to Yellow
Orange to Black
Orange to Red
Green to Yellow
Green to Black
Green to Red
Yellow to Black
Yellow to Red
Orange to ground
Green to ground
Yellow to ground
Black to ground
Red to ground
Then you need to understand what should be happening with position 2, then 3, and so on.
This is just an example, of course. There is no getting around understanding what the wiring diagram is telling you, and translating that into a test plan, and you'll drive yourself insane if you don't write it out and write down your results as you do each test.
Or, you could just load up the parts cannon and start shooting money at the problem. If you go that route, start with the switch and the belt.
/ loose altermnator belt causing many issues, yes ?? #12
Look for a mouse nest. If there is no mouse nest in the affected tractor area, I'm thinking you don't have any chewed wires. My experience is that mice don't chew and run; they chew and stay!
Hey Guys,
Look at the post REPLACING IGNTION SWITCH.
I tightened the belt [w a note too], and the wiring was fine, the ignition switch as bad. I posted how to replace it, which now it starts fine, runs fine and battery is doing well - thank you for your feedback.
BOBCAT 72" HYD MULCHING HEAD (A60429)
BOBCAT 72" HYD...
TANK MANIFOLD (A55745)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
