Need a lesson on the BX25 and similar sizes
/ Need a lesson on the BX25 and similar sizes #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
The BX25D really has caught my eye, mostly from viewing threads here. I feel I need to know more and how it compares with slightly bigger and slightly smaller models. Are those a better deal? I know almost nothing about B's or BX's other than having a larger B7800 (that I really like). I don't want TIER IV so I either have to buy used or a model under the emissions threshold.
I can guess why the BX25 is so popular because it works hard and is priced right. But is the BX2670 better? Does putting a package together with a backhoe and loader make the BX25 a far better deal? Would a B, for example, offer advantages over the BX25?
The smallest tractor I know much about is my B7800 and I like it a lot. On one hand I wonder if would be happier just getting a loader and backhoe for that rather than thinking about a BX25D? That would probably cost $9,000 or so? My uses would just be around a rural home and all that comes with it. I'm not building any roads; just household stuff, digging a small stump or planting things.
Just looking for an education so any info is welcome and appreciated.
/ Need a lesson on the BX25 and similar sizes #2
A BX 2670 is really the same just with a larger engine. I don't think you can get the factory backhoe on it though. I think its hard to beat the price of the BX with the factory backhoe. I think the smaller B models aren't that much more money but by the time you add a backhoe, I think it ends up being more money.
BX's are pretty small but you can still do a lot of work with one. They also make pretty decent mowers. A B will do more work and has larger tires, but based on what you described, a BX sounds like it would work.
/ Need a lesson on the BX25 and similar sizes #3
I call my BX25 my swiss army knife because it does so many things. The BX25 was designed for the backhoe and it isn't just an add-on. I have put in 300' of sewer line with no problems at all right after I bought mine. It could use some more weight as the hoe will pull it around when digging a stump ,but it will do the job eventually. It sits a little low so really rough terrain is something you have to watch but it sounds like the things you want to use it for all fall into its talents.
/ Need a lesson on the BX25 and similar sizes #4
I've had three B's and two BX's. My current is s BX2670. While I salivate over the thought of a BX25, I quickly remind myself that the hoe will be the most expensive ballast I could buy, and will collect more dust after initial projects are wiped out than dirt that'll collect on the bucket. I can rent a small track hoe with substantially more capacity for the three times I could really use it for a project other than setting an arborvitae. If you are like me and will use the BX for dedicated mowing and easy quick on/off loader work, the hoe will become a pain putting it on/off between mowing. You might be better off to bank those hoe jobs and rent a unit once a year. I think you'll find that while we all could use a hoe, it is the toothpick in the Swiss Army knife that is rarely used for that simple bush dig we thought we'd use it for.
I didn't realize the BX2670 was the same as the BX25 but with a bigger engine. Good to know. It sounds like the BX25 is the one to own. Does it escape the emissions stuff?
/ Need a lesson on the BX25 and similar sizes #6
I just did about 1000' of French drain, which is why I bought it. Heavy clay soil, and through a neighbor's driveway, including ripping out an old 10" culvert. I'm quite sure a bigger machine would have been faster, but it got the job done, with complete newbies at the controls (my sons and me).
I have other projects to do, including grading and trenching. I'm sure any pro would tell me it's too small for the jobs I have in mind, but I don't expect to have any problems other than it taking longer than a pro could afford to take.
When it's all done, I plan to sell it. It's overkill for a 1 acre property. Based on prices I see around me, I expect to get a good chunk of my money back.
Hope that helps.
/ Need a lesson on the BX25 and similar sizes #7
I have a BX 24 , It has done everything I ask and more
/ Need a lesson on the BX25 and similar sizes #8
You probably do not want a loader on a tractor without power steering.
BX series has only 9" ground clearance. If you will be doing woods work, 9" is not enough.
/ Need a lesson on the BX25 and similar sizes #9
The reason I got the BX25 back in the Fall of 2008 is BECAUSE it had the backhoe, and so it was a complete TLB, for a very reasonable price. In fact, I believe it was the only SCUT built tough enough for construction at the time. (Note the reinforced frame.)
I have done all kinds of things with it, including digging a trench through rock infested soil. The only frustration I have is the limit to the lifting capacity of the FEL, but even if I had a bigger tractor, I would still be frustrated with the capacity of the FEL, because it would just make me try and lift more stuff. Also, bxpanded.com has a lovely list of accessories that you can get, including a bucket expander that DOUBLES the heaped capacity of the FEL. (Great for snow.). Definitely check out that website if you're going to get a BX25. Also, check out the features of the new BX23S, which is what the BX25 has morphed into. There is a huge list of improvements that have a number of TBNers drooling.
Good luck with your search and do keep us posted!
/ Need a lesson on the BX25 and similar sizes #10
That seems like and odd comment, in all my years at TBN never seen a BX owner with a loader have any problems with steering , so that comment is out of left field I think. As for clearance, yes could be better , but I have built ATV trails thru my 40 acres of bush and swamp, got firewood etc etc and clearance never a problem , I did put a plywood protection plate underneath to prevent large sticks from getting up into cooling fan . So just by being reasonable and using common sense one can easily work in the bush with that clearance.
/ Need a lesson on the BX25 and similar sizes #11
I agree. Steering has never been an issue on my BX25, and in fact I think it does have power steering. Also, Bro-Tek and bxpanded.com both make great skid plates to protect the little plastic HST fan. (You MUST get a skid plate, because the HST fan is VERY vulnerable and VERY expensive to fix.)
And, come to think of it, clearance underneath has never been an issue for me, either, and I have had my BX25 for some 8 years now, with about 650 hours on it.
/ Need a lesson on the BX25 and similar sizes #12
That seems like an odd comment.
Here is the OP's thought in Post #1: "The smallest tractor I know much about is my B7800 and I like it a lot. On one hand I wonder if would be happier just getting a loader and backhoe for that rather than thinking about a BX25D?"
/ Need a lesson on the BX25 and similar sizes #13
I bought a BX in 2005 and in the following years my ONLY regret was not getting the backhoe model, even though I also have a much larger tractor with backhoe. There have been dozens of projects where the large backhoe could not get to the job due to transportabiliy or sheer size. These were projects that had to be dug by hand, something my 71 year old body doesn't do well with anymore. Once rented a mini-excavator to remove a stump... the thing cracked some concrete and tore up the yard getting into position. BX+hoe would have been much better. Adding a BH to your B is an alternative, but the little BX TLB packages is hard to beat.
/ Need a lesson on the BX25 and similar sizes #14
Oh yeah....add a thumb to the hoe and add a bunch more things you can do with it. I use it to hold tree trunks off the ground when cutting fire wood and picking up and placing large rocks......
/ Need a lesson on the BX25 and similar sizes #15
I have 1 acre of land , I bought a used bx2200 with the front end loader , It was the first small tractor I have ever owned or operated .
4 wheel drive was a must for me since my property had a good slope to it as well as pure clay.
I use my tractor mainly as a mower , the mowing deck is fantastic , everything has grease zirks , and the blades are very heavy duty , the drive belts never slip .
The frames on the bx2200 were not intended for a back hoe , but some people have installed a backhoe with great success , If I find a responsibly priced used backhoe I will do the same .
The loader only holds about 1 and a half wheel barrow's worth of dirt .
That darn plastic fan is a pain .
I have a bad knee from a old injury and the rocker pedal really gets it to hurting .
You did not say how much land you are going to use it on .
I personally would recommend making sure you buy a model with the heavier frame , also really take a good look at the pedals and make sure they are a good fit .
The power steering is a luxury that I really enjoy .
Also consider the roll bar , my roll bar is one piece and I can't mow to close to the live oak tree's without hitting , and I'm not cutting those big beautiful sweeping limbs.
/ Need a lesson on the BX25 and similar sizes #16
We have have/had several Kubota machines - 2 B's, L, and currently a MX 5100 and BX25D and a KX (Mini Ex). I like the BX the best for mowing hands down (Great on hills and sure maneuverable). The steering is a nonissue. I move gravel a lot and a full bucket causes no problems with steering.
Even having much larger machines and a dedicated hoe I still use the BX for a lot of jobs. It is easy on a yard even with the hoe and loader on, you can squeeze it in places larger machines don't fit and is great on gas.
It sounds like that for your uses it will work great. I also find that having a hoe is handier than you think - when it is right there it is easy to grab it for a quick job and it sure beats a shovel.
/ Need a lesson on the BX25 and similar sizes #17
I own a BX-25 and a B3030 with a cab. The BX is pretty much a finish tractor, it's nice for jobs after the fact. If you are really rural and didn't need a small machine, I would encourage you to look at the B-26. It's constructed for heavy duty stuff. In fact, while you can drop the back hoe, you can never remove the loader. And because its motor is 26 hp, it doesn't require that crazy emission baloney.
/ Need a lesson on the BX25 and similar sizes #18
Have a look at this!
Caterpillar 24in Digging Tooth Bucket Excavator Attachment (A59228)
Caterpillar 24in...
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Adams Tender Trailer (A61306)
Adams Tender...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
