ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,514
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
I have used a air compressor to blow it from the other end too. Like you said, it doesn't take long. If you use the AC method, don't just let the string feed as fast as it wants because it will ball up inside. You have to regulate the speed slightly.Put a small piece or rag on the end of a good nylon string and stick your vacuum cleaner at the other end it will pull it through in 1/2 a sec. flat. then you can pull your wire threw with the string. Soap or grease your wire.
