Ballast Tires Adding liquid ballast to tires. Is it a good idea?
   / Tires Adding liquid ballast to tires. Is it a good idea? #1
mytonka
Member
md
Terramite T5C
Hi Guys
I have tried to get some info on if it is a good idea to add liquid ballast to the tires. I do not want to hurt the TC5 however I like the idea of a more stable platform.
But will the added weight put more stress on the TC5? your opinions are valued.
   / Tires Adding liquid ballast to tires. Is it a good idea? #2
I'm not a fan of adding Calcium Chloride, an oxidizer, to tires, especially tube less tires. It will cause rims to rust in a heart beat.
I really don't think tire ballast will do much for stability or traction because the tires are not that big.
My 2004 T5C has narrow front and rear tires. The width of wheel base is only 4 feet.
the tires on my 2000 T5D is like newer Terramites, it's front and rear tires are much wider making it less likely to tip over. Not sure actual tire size but tires stick out the rear fender on the D model and are completely under rear fender on C model.
Now when it comes to traction, I feel I have better traction in mud with the narrower tire. The wider tire sits on top of the mud and spins.
Both the C and D models have the exact same front and rear axles.
The bolt pattern for both rims are the same.
I use a 300# weight that I pick up with back boom to transfer weight off front wheels and put weight on rear wheels when loading dirt. I find transferring weight off front wheels is needed when loading sand because he front wheels will go down in loose sand. The more I extend the rear boom back, the more weight I transfer off the front wheels.
   / Tires Adding liquid ballast to tires. Is it a good idea? #3
I've always had liquid ballast in my rear tractor tires. I've found it improves traction and enhances stability. My Kubota has approximately 70 gallons of Rimguard in each tire which adds 740# per tire. You can go to the Rimguard web site and they have tables that show how much weight would be added to each tire.
   / Tires Adding liquid ballast to tires. Is it a good idea? #4
Hi Guys
Liquid ballast is a must for all tractors that we use on our farm. We get better traction and improved stability. Calcium Chloride is not my preferred ballast because of corrosion issues. Ken Sweet
   / Tires Adding liquid ballast to tires. Is it a good idea? #5
In an ideal world the tires would be dry tubeless and the ballast all cast iron bolt on wheel weights.
   / Tires Adding liquid ballast to tires. Is it a good idea? #6
On my B2620 I have no wheel weights and no liquid ballast. From mowing (MMM) with a few hills and roadside shoulders to plowing, scooping dirt, sand, gravel etc. I don't have a traction or stability problem. I use the diff lock now and then. If I had a traction or stability problem I certainly would add liquid ballast or wheel weights to the tires/rims. Having rear counter balance is often needed when using the FEL. That's my experience so far.
Cheers,
Mike
   / Tires Adding liquid ballast to tires. Is it a good idea? #7
My T5B has fluid of some sort in the tires from previous owner. If I were to loose it I would immediately have it replaced. Think about the additional penetrating power it adds to the hoe bucket.
   / Tires Adding liquid ballast to tires. Is it a good idea? #8
How big are the tires ( size? )
If I didn't have liquid ballast in my tractor tires, I wouldn't be able to feed out round bales to my cows..
   / Tires Adding liquid ballast to tires. Is it a good idea? #9
I tend to agree with this. Unfortunately affordable wheel weights in this part of the world are only slightly more common than unicorns.
Depends what you want to do with the tractor though. I have a JD420 and 316, one with a blade and one with a FEL. Neither had weighted tires when I bought them. The unfilled/filled difference is the difference between not being able to dig and actually digging. Wheel weights helped but weren't as noticeable a difference as filling the tires. The 420 would not have needed filled tires if I left it as a lawn mower.
No idea if stability is improved. I've only been in one situation where I was concerned about turtling. After watching YouTube videos of tractors flipping I'm going to continue to operate like there is no safety margin.
   / Tires Adding liquid ballast to tires. Is it a good idea? #10
It depends what you do with the tractor. On bad slopes or heavy loader work, I understand the need for the weight. But then, you no longer can use that tractor for light duty things such as the lawn or septic system without a lot of effort. On the flat ground of the Midwest where I live, weights are more than adequate and I can add or subtract pretty easy. So it depends where you live and what you do.
The problem I have with filled tires is that I have never seen one that did not rot the wheels. My experience is that it always leaks past tubes, rusts and any flat is a disaster.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
