Kioti dk55
/ Kioti dk55 #1
duckruck
Member
Paradise, Texas
kioti dk55
Need to change hydro fluid. Bought 10 gals from Tractor Supply. Is that safe for my tractor.
/ Kioti dk55 #2
Which one did you get ?
The Traveler premium tractor/transmission fluid, or the Rotella HD tractor/transmission fluid would be fine.
/ Kioti dk55 #3
Unless it has changed the Rotella HD tractor/tranny fluid is Donax TD AKA Spirax S4 TXM
/ Kioti dk55 #4
Also is 10 gallon going to be enough? I bet your manual calls for more like 11 or 12? consult manual on fluids meeting specs.
/ Kioti dk55 #8
The hydraulilc oil normally used in the Kioti is a multi grade 10w-30 hydraulic oil. The Rotella HD is that multi grade oil. I have been using the Shell Donax TD which is now called the Spirax S4 TXM as RandyT mentioned. Great for my below freeing Winter temps and good in Summer. Members have reported good service with Tractor Supply's "Premium Hydraulic Oil", that is multi grade. From what I can find, 303 oil is a straight 20W oil. You probably would be fine in Texas being that your Winters aren't that cold but I think I would return it and get the multi grade oil of whichever brand you wanted.
Checked a Kioti oil chart and the DK55 is llisted at 10 gallons hydro fluid.
View attachment Lubricants-Chart-2012-07-20.pdf
/ Kioti dk55 #9
/ Kioti dk55 #10
The 303 oil is for old tractors (1974 and earlier). Do not use it in newer machines with HST, wet brakes, or wet clutches. You need a premium grade oil (as mentioned above) for several reasons, including viscosity and friction modifiers.
What ritcheyvs said.
Personally I would take the 303 back and get the Rotella HD or the Travelers Premium tractor/transmission fluid.
My DK 35 gear model takes 11+ gallons.
/ Kioti dk55
Thanks for your replies and advice. I am going to return the 303 and get the premium multi grade. Glad I waited for advice, thanks again.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
StarFire 3000 Receiver (A63116)
StarFire 3000...
2010 Hardi Navigator 3000 Pull Type Sprayer (A63116)
2010 Hardi...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
