Wifi to barn
   / Wifi to barn #41
Did the test...on new access point on other side of the house from main router...on the main router....and the one in the barn.
NO difference. In fact the barn was slightly faster, but it all had to do with the internet's condition at the time of the test. All test results was very close.
You can do an internal thru put test by measuring with a stopwatch how long it will take to download a large file from a PC on the other side if this wired ethernet link. Then move the the other side with the same laptop and download this large file again from a switch port on the same switch as the PC you are downloading from. This will give you an idea of how much thru put you are losing from using substandard CAT3 buried cable instead of a "proper" CAT5 or CAT6 cable. I am sure you are losing some, but I doubt it is significant. And for your purposes you have already proven that for browsing the internet, your internal thru put is faster than your internet connection to your internal network.
So unless you are having thru put issues on your internal network as you try to move large files from your "servers" to your "workstations" I doubt you would even notice.
Now for some possibly bad news. We didn't bring this up, but with buried cable you always run a risk of damage from lightning. Some areas are much more susceptible than others of course and there are many factors that can effect this. There are CAT5 plug in lightning/transient protection modules you can buy made by Polyphasor/Transtector and others. They aren't real cheap, and would likely be more expensive than the old junky access points/switches that are terminating the cable now. For some reason, some installations never seem to have any lightning problems, and others are plagued with it.
   / Wifi to barn
On researching this. I read about lightening problems. I'm calling it good at this point.
BTW, the slave access points are g/b, the main router also has N. In reality, as a user, it's immaterial.
   / Wifi to barn #43
Yep, good to go, and see what happens with the lightning risk is the way I would probably play it too. Right now you are out $6 and have good service. It doesn't get much better than that. :thumbsup:
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
Zero Turn Mower (A48082)
Zero Turn Mower...
