VFDs, Phases and voltage. OK, Now I am confused.
   / VFDs, Phases and voltage. OK, Now I am confused. #21
Transformer based phase converters fall short when the load varies. Good for fans or package refrigeration, but not so much for machine tools.
   / VFDs, Phases and voltage. OK, Now I am confused. #23
An air compressor sees "full load"with every piston rise and fall. Put the amp meter on and see. I've set the display on the VFD that supplies my 7.5 HP compressor, There is little evidence of load variation from when the pressure switch turns it on until it shuts off. So... Transformer based phase converters are NOT well suited to variable loads.
And NOT something the OP should be looking in to!
I checked Kijiji and found only dealers selling such units with no prices, so off I went to my contact. The guy probably has four hundred transformers in stock. Got a Marcus 5KVA, 600 Volt to 110/220 transformer for a couple hundred bucks CDN.
So plan is. 220 in to X-Former, 600 out to 5HP rated AC Tech MC series VFD out to 600 Volt 3phase 2 HP Motor on Milling mc.
   / VFDs, Phases and voltage. OK, Now I am confused. #25
That should work! You might want to include a disconnect switch somewhere close to the machine also.
Yes, And maybe a contactor to switch the primary power off from the machine, as the transformer might not be right there. 600 makes me nervous!
   / VFDs, Phases and voltage. OK, Now I am confused. #27
You'll need to verify you can disable input phase loss detection. Not all VFD's will run on 1 phase.
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
