What model of toolcat do I have?
   / What model of toolcat do I have? #1
ulmn
Member
ottawa
It's a 5600
Has independent suspension in each corner
High flow
2 speed
Double lifting arms
Air conditioning
I broke the front windshield out of it at the cottage and they need to know the first 3 digits of the serial number to order a new windshield.
And I'm not going back to the cottage till December 1st
   / What model of toolcat do I have? #3
The Boom would indicate that it is a C class or newer but its impossible to tell from your photos. Do you or a previous owner have an invoice from the dealer which will typically include the serial number? If you know the previous owners name I would suspect the dealer can find it in their system. The last windshield we lost in a Toolcat had to be air freighted from Chicago and was not cheap. If you have a key-less entry call the dealer and provide the code. If unchanged the code may provide you the answer...
It's at my cottage, and won't be heading back up till December
I can get the serial number then, but I want to get it ordered now.
What other pics or details would you need to tell me what model it is?
   / What model of toolcat do I have? #5
The front boom design did start with the C-series however Independent Suspension stated with the D-series. With Independent suspension and a Kubota engine it is either a D or F series. First 4 digits of serial denote the series. D starts with A0W1 and F is A94Y. Both of these use same part number windshield 7116155.
The G-series (newest model) also takes this same windshield.
Perfect, so your sure it will be that windshield? As it does have independent suspension.
How can I tell if it's a d or f series?
   / What model of toolcat do I have? #9
Your pictures are too small to see much detail.
I enlarged and rotated them:
   / What model of toolcat do I have? #10
5610's are just plain cool. I love the 3 point.
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2019 DODGE RAM 5500 HD SERVICE TRUCK (A54756)
2019 DODGE RAM...
40' CONTAINER (A54757)
MAHINDRA 1635 TRACTOR (A54756)
MAHINDRA 1635...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2018 Ford Explorer AWD SUV (A55758)
2018 Ford Explorer...
