UMMMMMMM
/ UMMMMMMM #1
DirtHauler
Gold Member
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
Had to replace my leaking PTO output shaft seal, pulled the seal out........and surprise! or not. These were the bearing shims!
/ UMMMMMMM #2
Seals often go bad for a reason... Most leaking seals leak due to damaged components alowing play in the shaft the seal is riding against. So yeah, no real surprise there. Good luck with repairs.
/ UMMMMMMM #3
Yep. With you 100% on this one Greg. Seals go bad from, 1. Age, 2. an outside force, which might be failed part or outside contamination.
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A61567)
2025 30in. Pallet...
2022 Horizon Trailer (A55973)
2022 Horizon...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 CATERPILLAR CB34B XW DOUBLE DRUM ROLLER (A62129)
2014 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
