Buying Advice New Land Owner; should I buy a tractor, something else?
   / New Land Owner; should I buy a tractor, something else? #1
FlowRoll
New Albany, IN
none yet
I recently bought around 4 acres that is on rolling hills (may buy another 20 behind my property soon). I am trying to determine if I should buy a tractor based on some of the projects that I want to complete on the property. I am currently in the middle of leveling a big piece of property on the side of the house for a shed and a large patio. All of this work is being done using a mini excavator that I rented. I still have some grading / compacting and some drainage work to do and am not liking how much I have to pay for renting. I have additional places that I want to level out as well close to our pond and we will be putting in some more sand there on the mini beach. I also have some trench work that needs to be done for drainage on the back of the property as well as for running electric down to the front of the property. I have a 400' driveway that is gravel. It is pretty compacted so I have only had to do a little bit of fill in certain areas with gravel but box blade would make maintenance of it easier. I have been using a zero turn for all of the lawn maintenance but a bush hog would be nice for the back field. We eventually plan on doing fruit trees and a garden on the back side of our property so a tiller would be nice for the garden. We have a lot of trees we want to plant / several that need to come down.
It seems like a tractor is one of those things that can do a little of everything with the right implements but is not great at anything. Would you all recommend a tractor and if so how do you determine the size to get. I know this isn't an easy question to answer but I thought I would start scanning the forum for advice.
Thanks,
FlowRoll
   / New Land Owner; should I buy a tractor, something else? #2
I agree on the doing a little of everything but not great at anything. It sounds like a brush hog and box blade will do most of what you are wanting to do.
How hard/rocky is your soil? A PHD on a 3 point works OK for some situations but for hard ground they are almost worthless as there is no down pressure. They are also tough on rocky soil if you get jammed as there is not way to reverse direction on the auger.
I have had pretty good luck buying equipment to use for projects and then selling it later. Seems to be quite a bit cheaper than renting if you can handle the maintenance/repairs.
"How hard/rocky is your soil? A PHD on a 3 point works OK for some situations but for hard ground they are almost worthless as there is no down pressure. They are also tough on rocky soil if you get jammed as there is not way to reverse direction on the auger."
We have a couple inches of topsoil underlain by clay then at around 2' - 5' we hit shale. Most of the leveling I am doing does not require going into the shale. I do want to build a garage into a hill eventually but that would require getting into the shale and would likely be hired out.
   / New Land Owner; should I buy a tractor, something else? #4
My, Oh my!
Tractors are designed to PULL. The primary tasks for tractors are performed from the (rear) Three Point Hitch and its associated Power Take Off (PTO).
Tractor Three Point Hitch: Since 1955 when Harry Ferguson's patents on the Three Point Hitch expired, no one has invented anything superior to the Three Point Hitch and Ferguson's design has become standard world wide.
Secondary tractor tasks are performed with the Front End Loader (FEL) bucket, tertiary tasks are performed from the rear/center drawbar, mostly dragging.
All the tasks you have outlined are traditional tractor tasks for which refined implements and attachments are readily available.
For four acres of sloped ground you could use quite a small tractor, however I recommend a moderately heavier, wider, more stable small tractor like the Kubota L2501/HST, especially if this will be your first tractor operating experience. You might get by for a time with an L2501 for twenty-four acres ~~~~. To further stability on hills and slopes, order the rear tires filled with a freeze-resistant liquid.
I would recommend a Ratchet Rake as your first bucket attachment and perhaps a Three Point Hitch Subsoiler as your first implement, for trenching, and underground water line and electric cable installations. Teamed, the Ratchet Rake and a Subsoiler will carry you awhile, in the tasks you have outlined, with minimal financial outlay.
KUBOTA L2501: http://www.kubota.com/product/LSeries/L2501.aspx
T-B-N Threads L2501: Google
SUBSOILER VIDEOS: Keylining Pasture with a Sub-soiler - YouTube
How to Use a Subsoiler - YouTube
RATCHET RAKE: Google
   / New Land Owner; should I buy a tractor, something else? #5
Most of the leveling I am doing does not require going into the shale. I want to build a garage into a hill eventually but that would require getting into the shale and would likely be hired out.
Wise.
   / New Land Owner; should I buy a tractor, something else? #6
Re: New Land Owner; should I buy a tractor, something else?
Such as ~~~~~~~~~~~~~~~?
   / New Land Owner; should I buy a tractor, something else? #7
Welcome to TBN. Patiently watch this thread. You'll get some great ideas. Understand that 4 acres is just a big yard to most posters here. :)
Haha, I assumed that when I bought the place. I bought a zero turn and it cuts great for most of the area and I have a walk behind for the really steep areas. I just started getting into some of the earthwork and was hating renting something when I know there are more economical ways to get what I want done. I have been looking into tractors and implements and also looking at used backhoes / skidsteers. It may be best for me to buy something used and sell it on the back end for the leveling work... and get a smaller tractor for everything else.
Thanks jeff for all the information!!
   / New Land Owner; should I buy a tractor, something else? #10
I think I was imagining the PHD being used to plant trees. They work really well for this purpose.
Might look at alternatives like the power trac
Versatile Tractors,Compact Tractors,Trailer Packages,Landscaping,Utility Vehicle Rentals,Mowers-Power Trac
Or for more digging work one of the little terramite or allmand backhoes you see at rental yards might be something you can buy and use for a while then sell for close to what you paid for it. They can be bought quite inexpensively.
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
