Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,901
I would definitely not take my loader or bucket off. Dragging the logs to me sounds like the safest option. If you insist on using the trailer I would mount a ball and receiver on the top of your front and loader and I would let the trailer back down the hill while you're driving forward.
You should be able to drop the Bucket if things start to get away from you. I would also keep some type of box blade or straight blade on the back of your tractor if you have it available for extra weight and you could also lower it if things start to get away from you. But again dragging logs one at a the time slowly down the hill sounds safer to me.
This sounds like a pretty good idea to me. Hitch mounted to the bucket. Tilt the bucket down a little. If you start to slide drop the bucket. Also, if doing it this way, have plenty of weight on the rear.
   / Tractors and wood! Show your pics #3,902
Thanks for the replies and insights...
It was never my intention to remove the FEL...I always fill the bucket with something for forward ballast/traction when moving heavy loads via the 3ph...regardless...
I considered using a blower to remove the leaves from the road but I've decided to heed the advice to just drag the logs down the hill...will try to get some pictures...keep forgetting to take a camera up on the hill...
   / Tractors and wood! Show your pics #3,903
Good call. Still be careful and remember to use four-wheel-drive and keep weight as low as possible at all times.
   / Tractors and wood! Show your pics #3,904
collecting fire wood in the forest with my valtra a93 and igland 4001 winch
   / Tractors and wood! Show your pics #3,906
/Pine - If you really mean 35% = 19˚ (and you weren't talking about 35˚) that's not exactly ideal, but certainly do-able with care. I would not back down something like that. Steering is different when backing, and my reflexes just aren't as quick in that direction. In good conditions, I'd just put my rounds in a trailer and drive down. My trailer is usually hooked to the logging winch, which I can drop to create some drag if needed, or I can lower the bucket on the FEL in an emergency. If conditions were less than good, I'd put on my v-bar tire chains. If it was too slippery for that, I probably wouldn't be driving on it, but would consider dragging the logs in a pinch. As mentioned earlier, I tend to avoid dragging when possible, especially going straight down a steep trail. That's a recipe for erosion problems around here, especially with some of the gully-washing storms we've had in recent years.
If you want to know the exact slope, there are some great smartphone apps. I use Theodolite and Clinometer. I got them for when I was working with a solar installer, since they were useful to determine the pitch of a roof, but I've been using them a lot when laying out trails through my woods. When I can, I try to lay trails out at 7% or less, since that lets me use broad-based dips as erosion control measures (which are easy to drive through), rather than putting in waterbars. I'm in the process of clearing a new trail to bypass one that was too steep on some group-owned land that I'm a part of. We used a dedicated clinometer as well as the clinometer app on my phone to lay it out. The new trail should minimize erosion, and thus the need to go back in and touch up the trail so often. (It's also more of a please to hike or ski.)
   / Tractors and wood! Show your pics #3,907
It was ANOTHER nice sunny day here today, and my helper came over to help me cut some firewood.
We have been cutting our way to a BIG "blown over" oak, and here it is,
First thing I did, was cut the BIG limbs off with my Jonsered 2260, then I skidded them out and piled them, to be cut into firewood lengths, at a later time. Anyway, here's what we cut off the limbs, before skidding them away,
AND, this is what's left of the tree now, we will also get to "it" another day too!
Did I mention that I LOVE my Jonsered 2260, lol
That's it for today!!
SR
   / Tractors and wood! Show your pics #3,908
Noodles!
   / Tractors and wood! Show your pics #3,910
How's the 3. Pt winch? Thought about getting a uniforest 35 for 28 hp just mahindra
1269 (A50490)
1269 (A50490)
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
