3PH Stabilizer Turnbuckles VERY Difficult to Turn
   / 3PH Stabilizer Turnbuckles VERY Difficult to Turn #11
I hated them so bad on my 2210 that I built telescoping pin type. Now life is good.
Might check with your JD dealer parts guy and see if there's some offered that would fit your tractor if you don't have the resources to build your own.
Nice work on those.
My L3400 had turnbuckles. The MX5100 hads telescoping ones.
Both have pros and cons. For alot of things I do like the telescoping kind, allthough there is no way to get all slop out like there is with the turnbuckles. With that heavy 1600# mower I have on the back, the ~1"-2" bit of slop that the stabilizers leave.....bend and wear out my lynch pins in a hurry. I may try to come up wit a way to take the residual slop out of the telescoping ones. Add a threaded end on one of them???
   / 3PH Stabilizer Turnbuckles VERY Difficult to Turn #12
Nice work on those.
On the little JD it's no problem. On the Ford and Kubota I have a plan. I pin one to center the attachment where I want it. Then, while carrying the attachment on the 3pt, I lean on it and move it one direction or the other until the "slop" is taken up and then hope for a pin hole on the other side. If I don't get what I want pushing it one direction, I try the other. I can usually pin an attachment very snug using that method.
   / 3PH Stabilizer Turnbuckles VERY Difficult to Turn #13
Must just be the pin spacing on the mower, because I have tried that and about an inch side to side is as best I can get. Which is still too much IMO. 1" allows 1600# to get up quite a bit of inertia
   / 3PH Stabilizer Turnbuckles VERY Difficult to Turn #14
An pounce of prevention = 1 pound of cure.
I oil mine twice a year! (then wire them as I once lost the barrel part!)
17101 (A55787)
17101 (A55787)
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
