JD 13' disc for my MX5100
   / JD 13' disc for my MX5100 #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Got my new-to-me disc. Overall not too bad. The bearings need replaced in one rear gang thats locked up. But the MX pulled it with no issues at all, both up and down hill in the corn field, then through the freshly plowed garden. With the one rear gang locked up, not sure if that makes it pull harder? or easier as it just loads up and dont cut in? But was happy with how it pulled testing it out, so went ahead and bought it for $500.
Some more pics:
IMG_20161107_175426370.jpgIMG_20161107_175427825_BURST000_COVER_TOP.jpgIMG_20161107_180100664.jpg
There was also a nice rock, that I talked him into included with the purchase.....all I got to do is see if the backhoe has the balls to get it home.
IMG_20161103_124457393.jpgIMG_20161103_124516540.jpgIMG_20161103_124524277.jpgIMG_20161103_124533735.jpg
   / JD 13' disc for my MX5100 #4
You'll get a LOT of use out of this disc. Heavy design. Very unique disc!!!! I've never saw one with the gangs offset like that. Any idea the purpose?
Also appears the hitch is a simple two point hinged hitch?? So the disc is unaffected by tractor elevation??
As for your rock. Here's my unusual rock. Excuse the snow cover. I had to drive my Kubota down a fairly good sized creek almost a mile, twice, to carry this one to our campground. It's sitting on a slab rock that I got from the same location. I love rocks. :)
   / JD 13' disc for my MX5100 #5
sounds you got a good deal! that setup is a little bit different than the JD disc I was pulling. Are you able to get the bearings from shoup or JD?
   / JD 13' disc for my MX5100 #6
Good point, I meant to mention bearings. Take it apart and go to your local auto parts store for the bearings. I got mine from O'Reilly's. Much cheaper than JD.
   / JD 13' disc for my MX5100 #7
JD used that design on several models, one thing it does is allows for a complete overlap between the front gangs as not to leave the small strip of untilled ground in the center. Some models and brands used a cultivator shank with a sweep mounted in the center of the disc behind the front gangs to cut the strip out.
   / JD 13' disc for my MX5100 #8
I had saw the cultivator shank solution, just hadn't saw the offset gangs. Makes the disc a bit "long" but should work great.
Love rocks too. I border everything with them. Anything from softball sized to 7000# monsters. Not sure on the hitch or the offset gangs. Reading I was doing mentioned this is a double-offset design.
Yea, bearings are still available ~$40
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
