Logging trailer
/ Logging trailer #1
mrfu
Shasta County ,CA
Mahindra 2615
Hi All
just finished up this logging trailer. Had to add some reinforcement to the cross members the axles attach to after accidentally stress testing it with the loader bucket when loading a log.
Otherwise it works great, need to get some new tires soon. The green part on the end acts as a support so it doesn't flop backwards. All the materials came from the remnant rack at a couple of local metal dealers.
Thanks for looking
Tom
/ Logging trailer #2
That'll be fun. Get some pics with logs on it when you can! :thumbsup:
/ Logging trailer #4
Trailer looks great. Wood is heavy I would add a bridge kicker under the metal for the axle. Can't tell by the pictures, do you have a 45 deg. brace from the beacket holding the axle to the inside?
/ Logging trailer #5
Looks nice. What kind of hubs and wheels did you use and where did you get them
/ Logging trailer
Leejohn
I've thought about doing just that under those bars, just thinking about how to do it. no braces but those plates are 1/4" and slide over that tube like a mortise and tenon.
Thanks for the comments they give me ideas to ponder
Tom
/ Logging trailer
ticolawnllc
Hubs and axles came from etrailer.com. axles are straight 1" with a 1 1/4" round end and hubs are 4 on 4 trailer axles. I think they are rated at 1200lbs each. tires and wheels are from a golf cart and came off of craigslist although if I was buying new it seems like surplus center has some that would work well.
Tom
/ Logging trailer #8
ticolawnllc Hubs and axles came from etrailer.com. axles are straight 1" with a 1 1/4" round end and hubs are 4 on 4 trailer axles. I think they are rated at 1200lbs each. tires and wheels are from a golf cart and came off of craigslist although if I was buying new it seems like surplus center has some that would work well. Tom
Thank you. I've been wanting to make a log cart and didn't know gulf cart wheels fit trailer axles.
/ Logging trailer #10
What is a "bridge kicker"?
/ Logging trailer #11
Looks like a great build. I've been debating doing something similar (but need to get a lot better at welding).
That green part might be a problem on my trails and the others in my area: It's hilly enough that many of the trails have waterbars or broad-based dips in them to help prevent erosion. Most of the water bars are deep enough that I can barely get a trailer through them now. I'd likely be dragging that green support when the trailer rode down into a waterbar. I'm guessing it would make it through the broad-based dips, but there are a lot of trails where the slope is steep enough that broad-based dips just won't work.
/ Logging trailer #13
King post and truss rod or strap to me.
Bruce
/ Logging trailer
the green thing comes out easily and is just used when loading to keep the back end from popping up.
I like the bridge kicker idea gotta think about it a while, my plan was to make something similarly shaped out of 3/16 plate
Tom
/ Logging trailer #16
I would prefer a boxed bridge, as a boogie arm is mostly loaded with torsion. straps add nothing to the torsional rigidity.
You are right about the torsional rigidity.
/ Logging trailer #17
Nice build, just a few ideas for the axle I've kept up with.
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
New/Unused 20ft Metal Farm Driveway Gate (A61166)
New/Unused 20ft...
2012 Ram 2500 4X4 Pick-Up Truck (A61568)
2012 Ram 2500 4X4...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
207270 (A52708)
207270 (A52708)
