Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #381
Hydrostatic transmissions are not complex.
That has never been my impression, and is not the impression of my B-I-L who owns the shop that I would use and whose assistance I would need. But, he is a farmer with mostly older tractors. His one "new" tractor (big JD)does have some synchro capabilities but is not hydro. Like me, he might just be assuming hydros are harder to work on because he is not familiar with them. But in reality the relative simplicity of hydro is not at issue for me. He and I are familiar with geared tractors and not familiar with hydros. He will not become familiar with hydros because he doesn't own one and doesn't want one. I'll never have one because my first and current tractor will likely also be my last and only tractor. And it has gears.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #382
When there's a problem with a hydro, when's the last time you heard of someone taking the cover off, to see if they can see what's going on?
It's a reality that you CAN do that with a gear drive tractor...
I asked my Kubota dealer, what if my hydro takes a dump?? He said: "no problem bring it in, Kubota has rebuilds"...
I guess most of his customers have a money tree in their back yard! lol
Didn't I recently read here on TBN of a guy waiting "months" for a warranty replacement hydro, for his tractor??
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #383
SR
The one or two hydro repairs that have been attempted by members here have been successful and involved replacing valves which were accessible from outside the case. The one I can remember was a Kubota L39 I believe. When fed clean oil, there is very little to go wrong with a hydro. Just like a gear train.:) Unlike clutches and throwout bearings. :)
If you would like to learn more about the workings of a hydro, this might be worth watching. The key words are "there are no parts prone to wear and tear such as clutches and brakes."
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #384
Here is another simplified moving diagram:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #385
That is soo cool James thanks!:thumbsup:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #386
SO, they never wear out and last forever... Then why does Kubota keep rebuilds in stock?
Why was a guy on here waiting for months for one to come in for his tractor??
I personally have seen more than one dead hydro... (dead meaning, tractor no longer goes!)
It's starting to smell in here like some one is "cleaning the barn"! Guess I better go put my boots on!
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #387
Good luck working thru this guys accent, but the video is pretty good:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #388
SR
Hey, I didn't say it, the Linde guy with the German accent said it.. Of course they wear out. And they wear out a lot faster if you don't keep the oil clean. :) But for the hours a home user puts on a Kubota tractor, you could consider them to be a lifetime item.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #389
your welcome Murph. I actually learn things on you tube.. It is not ALL **** and "epic fails",, but mostly..:)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #390
SR
The reason to wait months for a replacement is because that dealer probably has never replaced a hydro before and has never stocked one. The dead hydro's you have seen, were they on lawn mowers and garden tractors or something larger? The little hydro's in JD lawn mowers like mine won't last 300 hours. Mainly because you cannot change the oil.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
Nissan Forklift (A55973)
Nissan Forklift...
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
1995 Rinker Captiva 190 (A55315)
1995 Rinker...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
