FEL Cylinder Holder
/ FEL Cylinder Holder #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I had misgivings about working under a raised FEL and was looking for a way to make it somewhat safer. Ideas from others were to put it up against a tree, put a stand under it, something with boards under it and some suggeested putting cometjhing on cylinder shaft, so I did that.
I made two of these contraptions the other day and thought others could benefit from it.
I put sump pump hose around the shaft so I wouldn't ding it. Then I welded a couple 1-1/4 angle irons together along with a couple fittings so a bolt could hold it in place, just in case.
The confidence level is up on this. I painted it pink so I would be sure to see it, although it wasn't necessary.
/ FEL Cylinder Holder #2
Wouldn't be safer to remove the loader 5 minutes just wondering.
/ FEL Cylinder Holder #3
As long as it fits tight enough i like the idea :) So much safer than some things i have seen and they can be used at the location where you need to work on the tractor.
If I was going to have a major undertaking in the engine department, yes, I would probably take the FEL off. But for changing oil or light maintenance I figured this was a very safe way to go and only takes a minute.
/ FEL Cylinder Holder #5
Like it, also an angle, like 3 x 3 could do the same trick.
Fact I should make a set as my FEL always creeps down on its own, but not enough to spend on a new valve set.
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2012 International (A59230)
2012 International...
3142 (A63117)
3142 (A63117)
2025 Hydraulic Auger Bits Mini Excavator Attachment (A61572)
2025 Hydraulic...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
