Correct tire pressure (newb question)
/ Correct tire pressure (newb question) #1
pschrad
rosalia, wa
JD 870
Newb question here.
I have a JD 870 tractor that currently has turf tires mounted on it. Winter is coming and I am going to mount the Firestone Ag ties that came with it.
Could you suggest what the correct tire pressure should be for the rear Ag tires?
Firestone All Traction Field & Road
`12.4 x 24
Thanks
/ Correct tire pressure (newb question) #2
Won't they have the pressure range stamped on the sidewall?
/ Correct tire pressure (newb question) #3
:welcome:
To the TBN forum pschrad. I found this: Max Load and Inflation: 1870 lbs at 16 psi, on the Firestone website.
/ Correct tire pressure (newb question) #4
Owners manual says 12-16 psi for that tire size.
Most helpful..Thanks,Jim
-Paul
/ Correct tire pressure (newb question) #6
Hi pschrad,
I'm about 17 miles NW of you and hoping some of this rain may soon become snow also. Have a good day. Oosik
/ Correct tire pressure (newb question) #7
Just a reminder - if you have 4x4, you need will want to make sure that the Ag rear tires are in proportion to the front tires (assuming you dont have Ag fronts as well)
On my 2320 R-4 tires - i put in 16# of air and that thing bounced like a kids ball.. I had to lower it to around 12# so it didnt jar my insides out..
brian
/ Correct tire pressure (newb question) #8
I'm with that guy. When the dealer delivered my tractor i kept bouncing enough to shut the engine off with the seat safety switch.
I lowered the pressure so i had full width contact on pavement and found that worked great as my MAXIMUM pressure. For roots and rocks you can get by with even less....
Tires are designed to flex, you don't need to worry about heat build up like in a car...
Thanks pat32rf and thatguy for your tips.......................most helpful.
Can't wait until we get some snow.
-Paul
/ Correct tire pressure (newb question) #11
Don't recall my tire size but they are almost full of wwaf and have less than 14psi in them. The front have closer to 35psi...
/ Correct tire pressure (newb question) #12
Pressure depends on type of rating and what's printed on the sidewall.
/ Correct tire pressure (newb question) #13
Not really.. Its max load, including weight of the tractor, that you expect. There are charts for weight/load vs psi vs speed (that you are using the tire at). Rarely do you use the max on the sidewall for normal use.
Same goes for your car and truck tires..
/ Correct tire pressure (newb question) #14
One can always tell what the weight of load will be ?? :confused::confused: Speed rating may be governed by vehicle type.
All mine are at max.
/ Correct tire pressure (newb question) #15
Tire manufactures have charts online with consideration to size, plys, weight , speed and side hill applications .
/ Correct tire pressure (newb question) #16
-Paul
Your more than welcome to any I get at my place.
/ Correct tire pressure (newb question) #17
I run mine as soft as the load will allow with some sidewall flexing with the heaviest load. My back is more important to me than any tire that might fail from under inflation on the farm. My Silverado runs at the recommended 35 because I'm running 20" tires and they don't have the sidewall that can flex that a normal 78 type tire has. Seems the suspension is tuned for that pressure as the ride is smooth as silk as is the comfort of the seats........Fisher body at it's best.
/ Correct tire pressure (newb question) #19
Are you talking the max of the tractor manufacturer's recommended range, or the max stamped on the tire? The latter will generally give you poorer traction, poorer ride, and quicker wear on the center of your tread. It might give you better gas mileage, if you were running on pavement, but that's usually not the primary concern for running a tractor.
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
24in excavator tooth bucket (A61307)
24in excavator...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2022 EZ-GO ELITE...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
Generator (A61572)
Generator (A61572)
