Chains TN75D Hydraulic system adapting Hydraulic Chain saw
   / TN75D Hydraulic system adapting Hydraulic Chain saw #1
pfarmman
Holladay, TN
Ford New Holland
I have a NH TN75D tractor and it is equipped with a front end loader. I have recently acquired a Hydraulic Driven Chainsaw which has to be attached into the hydraulic system. It is set up with twin hoses one of which is the pressure side and the other the return. The four hydraulic ports that are mounted on the rear of tractor are used by and controlled by The Buckets Joy Stick, is there any place that i can buy an adapter of some design that can be hooked into the pressure and return side of the hydraulic system? Thanks for any help you may be able to give me.
   / TN75D Hydraulic system adapting Hydraulic Chain saw #2
Besides just disconnecting one of the loader circuits with the loader parked on the ground and plugging the saw into one set of ports, you could remove the tube on the right of the remote stack. Have a hoses made up with a coupler set. Attach the saw to the set to use. Attach the couplers back together when done as this is a power beyond line. All connecting and disconnecting of lines should be done with the tracor off.
The Joy stick controller is always centered to keep the bucket stationary unless depressed in one direction or another to move it. There is no pressure coming out of any port unless you hold the joy stick depressed...? Thanks for answering me.
2019 Deere 35G (A53317)
2019 Deere 35G...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
