Fuel Caddy?
   / Fuel Caddy? #11
It wasn't cheap. The steel tank was about $250, $350 or so for the fillrite 15 gpm pump with auto nozzle (a must for my needs), $75 for the 2 filters and steel nipples, another $45 for a sheet of 3/4" plywood, 4 steel castors, and a few pieces of scrap 2x6. But it sure is satisfying to pump that diesel and have it cut off right when it's full!
   / Fuel Caddy?
What are everyone's thoughts about using a gravity drain, instead of a pump? I'm only fueling two machines at the moment. I don't think I'm using more than 100 gallons a year currently.
I'm just trying to figure out:
1) How to connect a gravity drain (portable) and keep filters on it.
2) Any concerns with the diesel sitting for extended periods of time? If I want off road, I have to buy a minimum of 150 gallons and have it delivered to my house. I really don't like the idea of having a tank outside. Stepping up to a tank that size would make the payoff from using off road diesel take forever.
Thoughts/opinions?
   / Fuel Caddy? #14
My BX 25 handles a 50 GL transfer tank using clamp on forks. I strap it on to the FEL just to be safe after I had it slide off the forks while in the air. Mine is on wheels and I use a hand pump with 10 micron filter. Stay with Steel as aluminum corrodes with any moisture and cheaper. I bought mine at WILCO CO-OP; they are everywhere in OR. Tank and pump was under $400. I have two; one diesel and one gas and go through 100 GL each per year
Ron
   / Fuel Caddy?
What about issues with diesel sitting for extended periods of time? Let say I find a deal on a larger tank, but the diesel might be in there for a year'ish? Will it be okay? What additives etc should I be adding to the tank?
I add Stanadyne now (spelling is probably wrong). My local co-op will sell me a 150 gal tank on a stand for fairly cheap and fill it themselves with off road diesel.
   / Fuel Caddy? #16
I've had diesel sit for a lot longer than a year, it's just fine....AS LONG as you keep the water out of it.
I don't use any additives at all...
SR
   / Fuel Caddy? #17
Looks like you can't get a tank (50gal'ish) for less than $500?
What would be nice for me is to have dual filters and gravity drain the tank. I could make something to keep it in the air. Save me the cost of an electric pump. plus my B3200 only holds 8 gallons, so an 8gpm pump will be a little fast.
I bought two Delta steel 50 gallon transfer tanks off CL for $50 @ about two years ago. I'm shocked that the price from TSC is now $250@. Bought a hand pump for transfer from HF. A hand pump is not that bad. We had a 250 gallon tank on the "farm" where I grew up and it's a little exercise but not bad.
SR
I've had diesel sit for about 5 years at least, a little biocide and water management keeps it good.
   / Fuel Caddy? #18
I, like many of you am tired of the 5 gallon fill ups. My plan was to get a 100-150 gallon truck bed tank, then mount it to a pallet. I can load it in my truck bed to fill it up then build a stand to set it on and gravity feed to the tractor. So far it sounds good in my head, just need to get past the thinking part and start doing.:laughing:
   / Fuel Caddy? #19
I think that's a pretty good idea. A lot of those truck tanks have lifting eyes too, so you could sling it instead of messing with bucket forks (if they are rated for a full tank). I'm glad I have the bucket forks, but they put the load so far out in front of the bucket that I lose half of my lift capacity on the CUT. It's also a bit "springy" way out there. I much prefer slinging when I can.
   / Fuel Caddy? #20
Good to know about the lifting eyes. I do have pallet forks so either way would work.
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2014 Dodge Grand Caravan (A50324)
2014 Dodge Grand...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
