New Splitter On the Way -- Questions
   / New Splitter On the Way -- Questions #2
I would put the recommended oil in it stated in your manual when you get it. I wouldn't use used oil at first as there is a break in of parts when new.
   / New Splitter On the Way -- Questions #3
Very simple. Just use what is recommended in your owners manual.
   / New Splitter On the Way -- Questions #4
If you spend that much money for a splitter then by all means, use the type of fluid the manual recommends.
I bought a new splitter and used the recommended Dexron three 25 years ago and it is still going good without a problem. I would not use used oil or a different type than recommended.
The only reason I asked was I'll have 20G+ of Super UDT removed from my tractor and that's free ;)
I did notice the spec. requirement some of the oil I googled was VERY VERY cheap compared to Super UDT :thumbsup:
   / New Splitter On the Way -- Questions #6
If the oil were still good, why wouldn't you save the money and just leave it in the tractor?
If it's bad enough you don't trust it in the tractor, why would you trust it in a brand new splitter?
My thought behind the idea is:
Because it's not a 50k$+ tractor that has numerous hydraulic motors, valves, cylinders, etc...(that are PITA to get aces to and work on too) and it's not used for hours on end day after day like a tractor is.
It's a wood splitter, it has a pump 1 cylinder and 1 valve and will be used MUCH less. (Additionally these are all <$500 items that can be swapped in minutes.)
The "break in" on new fluid = dumping it in xHours anyway, so I thought why not use the 'used' (yet filtered) Super UDT I already will have excess off.
When the break-in is done and the hydro fluid is even more dirty (small particles as again, it has a filter) I can toss it and replace it with fluid that will likely last 10+ years.
It was just a thought I had to save couple hundred bucks on fluid :)
After all the log splitter will need around 15G in it so 30G after first flush is a hefty bill, but again it should be fine for 10+ years after the first 'clean' fill :)
   / New Splitter On the Way -- Questions #8
I have never "broke in" a splitter. Or done a oil change shortly after purchase or build. Change filter after splitting the first few cord....sure. but not oil
By "broke in" I simply meant running for x Hours then doing a fluid change. Common practice with pretty much any oil, hydraulic, etc,... system is to do a drain and refill after x Hours.
Why is that not warranted for a log splitter?
I don't know about others but when I use the splitter it's for hours on end and the fluid gets hot... this new splitter with 15g should stay a bit cooler ;) Hehe
I would much rather NOT change the fluid :) save me a chunk of $$... also why I was going to run the filtered tractor fluid in it, then drain and refill with new.
   / New Splitter On the Way -- Questions #10
I recently ordered a: LSED14534 34 Ton Commercial Grade Log Splitter - Swisher
What hydraulic fluid would you guys suggest?
I have a Kubuta and will be changing fluid, is it not advised to use that fluid even though it's filtered?
Any other 'favorite' lube for splitters I should be aware of :D :D
Use whatever the manual recommends. I'm running ATF in mine because the previous owner already had ATF in it. My splitter came with the house. The manual said use either ATF or hydraulic oil as in UTF. UTF is probably cheaper but you don't need a premium grade because all you're doing is running one cylinder with it. It's not like you're trying to lube running gears, brakes or a HST drive as in a tractor.
2012 Ford Focus Hatchback (A48082)
2012 Ford Focus...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
197637 (A50459)
197637 (A50459)
2018 John Deere 645FD Flex Draper Head (A50657)
2018 John Deere...
