Hydraulic Top Link
/ Hydraulic Top Link #1
Kryton619
Ontario, Canada
Mahindra 3016 Yanmar VIO 55 Excavator
Got the new hydraulic top link working. I won't miss hopping off of the tractor to make adjustments. I purchased three foot hoses, so now I will just cut them down to size to make it look a littler neater.
/ Hydraulic Top Link #3
Looking good, I expect the road will look better than ever now.
/ Hydraulic Top Link #5
Looks good...I do have two suggestions...for a neater fit buy a couple of custom hoses and keep the 3'ers for emergency spares...
Also...you may not know it yet but you need a hydraulic side link (and a second set of remotes)...without being able to adjust the lateral pitch of a blade...it will follow what's there...makes working/changing crowns a breeze...
Thanks for the suggestions. I will either cut the 3 footers or just have new ones made up...not a big deal.
Yes...I would like to get working on a tilt cylinder, however, my next project is going to be a 3rd function for my grapple. I currently use the rear remotes for the grapple...but now with the top link, I have to free up the remotes for that.
/ Hydraulic Top Link #7
Dont go too short on the hoses. You need to have full range of motion, without stressing the hoses, with ALL of your implements.
What ends did you use for the toplink? Those almost look like lower links, ones made to replace your lower two balls. All of the toplink ones I found when doing mine, were more rounded where they get welded to the cylinder. I was looking for one like you have, but couldnt find any other than the lowers.
I actually used bottom links for the top link and then used 7/8" to 3/4" bushings inside the balls to accommodate the smaller pin size.
/ Hydraulic Top Link #9
That's what I thought it looked like
/ Hydraulic Top Link #10
Hello Kryton. I posted earlier this evening this exact question. I must have got off my tractor 15 times today while using the box blade to adjust the top link. I am seriously considering installing a hydraulic top link. Could you give me some advice on what size cylinder you bought? Did you go with the 3,000 PSI cylinder? I found one this evening on Surplus Center's website. Picture is below.
Any advice you can offer is greatly appreciated.
/ Hydraulic Top Link #11
For your tractor I'd go with a 2.5" diameter or 3" diameter cylinder. Measure your implements to find what length and stroke you want. IF your manual toplink works fine, and you havent found yourself wishing for more range of motion, then measure it retracted and extended and that will give you an idea.
Also do some reading about the toplinks with the check-valves. IF your remote valve has float, and you get a toplink like pictured, float wont work.
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59909)
2018 VOLVO VNL...
2023 Global Trailers GT302 30ft. 60YD T/A End Dump Trailer (A61568)
2023 Global...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
