1526 vs Max 26XL
/ 1526 vs Max 26XL #1
matemike
Member
Brazoria, Texas
New Holland T1510
Hello all, new here, 2nd post.
I've been researching for about a month and have pretty much decided on Mahindra. I will still probably spend another month contemplating before I make my first ever own tractor purchase. I've seen many threads comparing the eMax to the Max lines and the 1538 to the 2538, but nothing comparing the Max line to the 1500 series. Particularly I'm looking between the largest of the Max line the Max 26XL and the smallest of the 1500 line being the 1526. Interested in nothing but HST. I test drove and looked at financing plans for a Max 26XL. Nice little tractor with a decent price too.
I live on 2.5 acres and have been getting by for three years now with wheel barrows, a 4 wheeler and my truck bed for all of our large gardening work. Seems like we are always having to add mulch to a few thousand square feet of gardens around the house and pool. We've resorted to having dump trucks deliver it in 6 to 10 yard loads at a time. We usually use wheel barrows to spread the mulch or I've also borrowed the neighbors 75 hp tractor which is extremely useful but cumbersome around the house. Our place also has 10 palm trees that need trimming two times a year and palm leaves aren't small. Needless to say that a burn pile is almost always present. As soon as we burn one down, I gather it all back up by hand and start building it up again. A little tractor will suit my needs exponentially well. I'd store it and even use it in my 30x40 shop for lifting things up to my loft or the occasional thing into my truck bed, etc.
But just how compact or sub compact will suit me best?
It seems to me on paper that the Max 26XL can do everything the 1526 can but it can do it in tighter spaces. The specs show they both have the same engine, a Mitsubishi 3 cylinder, indirect injection, 25.6 hp diesel. The 1526 can lift a mere 158 more lbs to full height with the FEL and it has only 105 more lbs of break out force (curling) capability. It can also raise these loads only 2" higher than the max 26. So my main question is why on earth would anyone choose a Mahindra 1526 over the Max 26XL? The max is smaller and will get more places bringing the same amount of power with it along with less chance of getting stuck being lighter. In addition for being lighter it will fit on a trailer and tow easier as well. I think all the 1526 has going for it are the larger tires, higher ground clearance, a little more FEL volume and lifting capacity, and more of a "real" tractor look.
My main concern is that the Max line is sort of considered a sub-compact tractor, also referred to as a riding mower on steroids. I do not want to sell myself short and find that the first time I go to push up my half burnt brush pile back together that the max couldn't do it. But if it couldn't do it then the 1526 would have probably fallen short as well being they have the same engine power plant. So this then leads me into feeling like if I'm going to get a tractor then I should be getting a real tractor and step up to the 1533. This is a decent upgrade being a direct injected 4 cyl engine with 34.5 hp. The 1533 loader can lift loads over a foot higher then the 26 hp tractors and it is all on the same frame as the 1526. A little more cumbersome than the Max series, but I think I could still get around the house, fences, gates and gardens with the 1500 series being that I made a JD 75 hp tractor on ags work back there.
FWIW I do not plan to mow with any newly purchased tractor. Currently I have a yard guy who cuts, edges and cleans for an incredible price. My wife and I have both agreed that if he ever leaves our area that we'll buy our own zero turn. The only attachments I think I'd ever get for this tractor is a box blade and maybe a little tiller, so PTO power is not a huge issue to me. The loader capability and the nimbleness of the tractor are my main concerns. My property is south of Houston Texas and nothing but flat San Augustine grass, except where the burn pile is which is outside of the back fence; still on my property but almost down in a ditch. When it's wet the 4wd will be required. Just wanting to make the sure the Max 26xl is the real deal as lots of reviews says it is.Or, if I'm missing something about the 1526 that makes it exceed the max 26 then please tell me. But tell me too if skipping the 1526 and going to the 1533 is smarter as many forum guys say to always get something bigger than what you think you need for the just in case scenario.
Thanks for all your help.
/ 1526 vs Max 26XL #2
As you stated the Max 26XL would be more along the lines of a sub-compact and the 1533 a compact tractor. It doesn't sound like you have a need for anything bigger than the Max. Being in Texas there's no worry about pushing and moving heavy wet snow. Maybe you should rent a tractor for a day or a weekend and see what your needs really are...size wise. Looks like there's a NES Rentals 20 minutes from you and I'm sure they deliver the rental.
Backhoe, 8-1 Dig, Diesel, 4WD - NES Rentals
/ 1526 vs Max 26XL #3
With a small property like yours the Max 26XL is more than enough tractor for your chores. It doesn't even come close to being a riding lawn mower on steroids. And by the way, if it make you feel better, Mahindra refers to the Max as a mid-compact, not a sub-compact.
/ 1526 vs Max 26XL #5
the 1526 is a whole lot more tractor than the max. Wider, taller, heavier, more stable foot print. The three speed gears in the hst is worth the price difference alone.
they are really different machines.Just sit on one and you'll immediately know the difference.
I agree with the poster above, that the max is all you need..
/ 1526 vs Max 26XL
Thank you, that is the exact kind of answer I was looking to see; and I figured so about everything or more than I need.
Might be worth taking a peek at a thread comparing a Kubota B series to the Max 26XL, CUT vs SCUT....
Been all through that thread. Thanks. Considering the Kub 2650 because it seems to be right in between the max 26 and 1526 sizes. Wish I knew if the B2650 were a direct injection engine.
I did sit on one and noticed everything you said. Very nice tractor indeed. The 3 speed HST upgrade makes sense. But still, why is a suitable engine in a 1800 lb tractor considered suitable in a 2400 lb tractor? Is the extra HST range a lower gear so the 25.6 hp engine can drive it with less effort? It just seemed like going to the 1500 series meant the 34.5 hp engine was a no-brainer besides the hit on the bank account.
/ 1526 vs Max 26XL #7
It's not a direct injection engine...
/ 1526 vs Max 26XL #8
the low gear, more weight turns it into a bulldozer, before spinning the tires. Better pulling heavy loads and better braking going down hills. M range is for general overall use and H is for level ground, road use though I've used H plowing snow and carting bucket loads of material from the source pile to the place of use. The range of gears is very handy.
the heavier overall weight along with bigger wheels and tires gives you better traction along with better stability. I think you'll find better overall capability even though the engines are rated the same hp, on paper anyways.
Just answering your question. I still think the max would be best for your situation.
/ 1526 vs Max 26XL #9
See My threads on what I did with my Max28. The Loader on a 1526 is way more useful than a Max 26 as the Max26 comparatively has low curl strength, even if it can lift 90% of what a 1526 can at the pins. I suspect where the breakout force is measured is different on the 1526 to the Max, so take the numbers with a grain of salt. Putting 1526 curl cylinders on my max made a HUGE difference.
To use the lift capacity of a Max26, for safety, I'd hang a back hoe or 3 Pt counter weight and load the tires. Max28/26 have an very strong 3 Pt Hitch, but the frame is a lot less stiff than the 1526.
I wanted a strong small tractor, I got it with the Max, but for general one tractor operation, it might be too small. Value wise, you get more metal with a 1526.
That said, small is a backsaver.
Power wise, the Max is quite ample, the 1526 will be fine, if you don't expect to much from the PTO.
/ 1526 vs Max 26XL #10
the Max 26xl will do everything you need... plus on a smaller scale... I run one on my 65 acres... backhoe digs everything I've needed done, 5' brush hog, 51" tiller, single drop plow, 6' York rake...
this sub handles it all... if it wont lift it, it pushes it out of the way, or if I cant pull a boulder, I dig a hole right next to it deep enough to cover...
you wont be unsatisfied if you get the 26... good luck...
/ 1526 vs Max 26XL #11
On 2.5 acres, if not major projects where the larger size makes a significant difference, get the Max.
/ 1526 vs Max 26XL
Pretty much sold on the max. Thanks a ton everyone!
My last personal battle is that the Kubota dealer is only 14 miles away with nothing but smooth open highway, one exit and one turn. My contact at Kubota has also been very accommodating through e-mail and he is just overall cool and polite.
The Mahindra dealer is 20 miles away, but those last 6 miles are horrible (I hate highway 35 in Alvin). I live far outside of Houston because I don't like traffic. I figure I'm looking into this part way too much because hopefully trips to the dealership won't be often after the purchase, and if they are due to problems then I might be dropping whatever brand I went with anyway.
That being said, the Mahindra dealer has been good too, no complaints, just not as personal and polite as the Kubota guy. Just reminding myself I'm buying the tractor and the Max is what I want, I'm not buying a friend or hiring a new coworker to deal with everyday.
/ 1526 vs Max 26XL #13
If you think you will not be keeping the Max for 7-10 years, get the Kubota. If you move to another property, you will get that I want bigger urge. Resale should be so much better with Kubota, you cost of ownership will be less. (Like comparing a used Ford to a Honda.) B2601 with LA 434, especially with a 3 speed HST is very nice. You do give up about 200 Lbs in weight and capacity with orange. (PS the Max will turn pink if left in sun.)
I really like the excellent Shuttle shift on my Max28, as it is far better than my old Kubota's 3 x 2 Straight gear transmission. I prefer 8 speed shuttle to a 2 speed hydro.
In my case, I bought a leftover Max28, saving more than $5000 over a new B2650 Kubota.
/ 1526 vs Max 26XL #14
It's hard to beat the seat comfort, the refinement and ergonomics of the control layout, plus the smoothness of engine and hydraulics for the B2650. Since loader work is a big part of your plan for this tractor, you will find that the location of the brakes on the left side and the hydrostatic pedal on the right allow for brake steering when using the FEL.
/ 1526 vs Max 26XL #15
You can't seem to make up your mind although the OP did. LOL
/ 1526 vs Max 26XL #16
Funny thing I can get cutting brake action with my shuttle with no sweat and the brake pedals are both on the right while the clutch is on the left.
/ 1526 vs Max 26XL #17
Good point and maybe that is part of the answer; MATEMIKE, you may prefer a shuttle shift in either Mahindra for FEL work.
/ 1526 vs Max 26XL
If you think you will not be keeping the Max for 7-10 years, get the Kubota. (PS the Max will turn pink if left in sun.)
I "plan" on keeping whatever tractor for years/decades to come. We are pretty settled in our home based on house size, property size and location. That is even considering IF I ever got the job I've been applying for for some time now. Living arrangements should not need to change.
I really fear the "pink" look of the Mahindras. I'll keep it in my 30x40 insulated metal building though and that should alleviate the color change. Why can't Mahindra use a better paint like autobody quality? I had a red f150 for 9 years that lived in the texas sun it's whole life and it didn't fade in the slightest. Washed it monthly and waxed it twice a year.
That had Kubota not quite ruled out, but I don't need the scoop of dirt to have a smooth ride while the loader is being picked up. I know it'll make the entire tractor more jerky, but I will be able to live with it. I didn't notice anything uncomfortable about my neighbors 75hp JD loader controls and I felt the Max26 was smoother than that beast during my test drive. Would a kubota be that much smoother to notice if not driven back to back comparing to the Max?
Ultimately the price difference is a factor. At first I was figuring they come out the same after the Mahindra dealer offers 5.24% financing for 84 months and the Kubota dealer offered 0% financing for 60 months. I'd get lower monthly payments on the Mahindra, but the two tractors (B2601 and Max 26) end up costing nearly the same after 84 months paid on mahindra and 60 months paid on Kubota. Actually the Mahindra cost $848 more than a 2601 7 years later.
Then I may have discovered a cheaper route on the Mahindra, waiting for a reply from the dealer. Here's what i came up with
Max26 0% = $20,405 (total paid @$298.71/mo for 72)
+ $535
B2601 = $20,940 (total paid @$349.00/mo for 60)
+ $848
Max26=$21,788 ( total paid @$259.84/mo for 84 )
+ $772
B2650 = $22,560 (total paid @$376/mo for 60)
all those prices include a canopy and tax in case they looked high to anyone.
Set on HST. I feel a shuttle shift, although miles ahead of a rudimentary box transmission, could cause left leg fatigue for myself or my wife if using the tractor for hours at a time and even more so if being used days and days in a row.
/ 1526 vs Max 26XL #19
the pink paint issue doesn't seem to be much of an issue in later model machines.
Club Car Emergency Cart (A64557)
Club Car Emergency...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
