Bush Hog mod question
/ Bush Hog mod question #1
Mike9
Ghent, NY
Kubota B6200HST-D, Cub 1440, Huskee 4200 LST
Is there any downside to drilling a couple of drain holes in the pan of my Bush Hog SQ48? When I took it apart because the blades were rusted to the pan the top of the pan was full of crud and of course rust. Anyone try this? I was also thinking of fab'ing a cover plate for the blade access hole to keep water out.
/ Bush Hog mod question #2
I think many bush hogs come with a cover plate for the blade bolt access hole but they don't always stay put. I drilled 4 ea 1/2" holes in the deck around the gear mount which allows the water to drain out regardless of how the bush hog is setting. This part of my BH deck is completely enclosed so it needed some drain holes. I do have to keep the area cleared of grass due to the small size hole (1/2" was the largest bit I had).
I don't see anything wrong with putting some holes in the stump jumper if you want to do that as long as you keep them round so they don't propagate cracks. I didn't do mine simply because I hate drilling from underneath which is where you would need to be to get to the outside edge where the upturned lip is and where water would accumulate.
If you do decide to work under your equipment, be sure to safely block it up and wear eye protection.
/ Bush Hog mod question #3
do you mean by "pan" the stump jumper? so the blades were not rotating in relation to the "pan"? doesn't sound right. when the retaining bolts are properly tightened, the blades should should still rotate freely. if you start drilling on rotational equip, you'll want to do it carefully so as not to create an imbalance. my advice is to remove the blades, clean up surfaces, and ensure everything works as intended. if the manufacturer intended drain holes, they would be in place already. apology if i misread your post best regards
/ Bush Hog mod question #4
I can see the logic in fabbing a cover for the blade bolt access hole, & would think that will solve most water collecting in the stump jumper issues. As to drilling the stump jumper for drainage, you'd probably need holes large enough they wouldnt plug with grass and debris, and would be a POTENTIAL place for cracks to start.
/ Bush Hog mod question #5
Those should use shouldered bolts, and I personally wouldn't drill, but a piece of flat 1/8" sheet with a bead of rtv should cover those bolt access holes water tight.
Yes I mean the stump jumper. I got this unit last year and have just brought it down and crawled under - the blades were frozen in place, tail wheel frozen in place etc, etc. I got everything swinging again, but as is my style I did a complete tear down, clean, prime, paint, zerks and rebuild to the unit. I did the same to the tractor an '89 Kubota B6200HST-D @ 290hrs., Kubota 48" rototiller and this Bush Hog SQ48-3 for $1,500 I bought from a friend - it was too good to pass up and worth putting the little bit of money for parts and time into for the years of continued service they will provide. Another friend of mine has a spare slip clutch he'll give me and I bought new blades, safety decals, main cotter pin and lock washers today for $65 (it pays to shop local trust me) then painted those and the old hardware so I can reassemble, then flip and redo the top side. The savings on the slip clutch will pay for a new laminated tail wheel as mine is dry rotted.
Only problem is . . . now I want to go bigger!! Jeeze Louise - does it ever stop? ? ?
/ Bush Hog mod question #7
All that work & effort, and no pic's?? Shame on you!!
/ Bush Hog mod question #8
mike 9: sounds like you've done well in refurbishing the hog and that you know what you're doing. will pass on whether to drill moisture weep holes in the stump jumper. given that you've cleaned up and have the blades rotating freely, think you will be just fine! maybe the hog sat for a long time prior unused...but, again, think what you've done is very adequate. in my own case, i just cover it during off season, keep the gear box oil in good shape, lube drive line regularly, and sharpen blades a few time a season. looks to me you're on the right path.
I put it back together today so I can flip it and redo the top side. Pics as requested -
Next step -
/ Bush Hog mod question #10
I need to do that also,good job
/ Bush Hog mod question #12
I'm thinking a small coverplate for the blade nut removal hole. I never thought of doing that on my BH286, but the top side of the stump jumper on mine also builds up debris and them gets rainwater in there through the hole. Good idea!
/ Bush Hog mod question #13
just make a quick removable plug for each side of access hole after use each time if you're concerned. sure, some kind of sliding/bolted cover might work, but moisture will find it's way through anyway..... come on, wouldn't the manufacturer provide if necessary? use it during season, cover or garage during winter. mike 9: when blades were solidly rusted to the jumper from original seller, doesn't that seem like long tern neglect/lack of use rather than design fault? from your pics, you've done a great job to bring it to useful life again. personally, don't see how a small amt of moisture could make a big difference in the integrity of the jumper within our lifetimes. but only imho
You're right it was neglected by the previous owners. For instance the tail boom was chock full of decomposed hickory nuts as was the stump jump pan. Freakin' squirrels can wreak havoc with equipment. When I rebuilt the front of the tractor last fall I removed a mouse nest the size of a football from behind the dash panel. I store it and the tiller under cover and park my tractor in my garage - I know . . . "you know you're a red neck when . . . " LOL.
Here are before and after tractor pics -
Before - my son and grandson taking for a spin after arrival.
During -
And today -
/ Bush Hog mod question #16
I cut a 6x 18" hole in the top of my Hawkline 6 ft hog to make blade sharpening easier. The piece removed became the bolt-on cover.
Works fine.
Good luck
/ Bush Hog mod question #18
I assume it is to sharpen the blades in place. Personally I'd never sharpen my rotary cutter bars. Sharp blades mean sharp stumps when you are cutting brush & I prefer my tires unpunctured.
/ Bush Hog mod question #19
I'm coming up on about 10 years on my hog and figure it might be about due for its first "touch-up".
My boom pole paid for itself again today. I lowered the 'hog with it then found the balance point with chain and lifted it up then laid three skids on blocks under it and let'er down. I love that thing!! With this weeks forecast I might get this finished by the weekend.
Peacock Statue (A64127)
Peacock Statue...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
