Just bought first tractor and got ripped off
   / Just bought first tractor and got ripped off #141
What I'm asking is there a technical reason to grind it flat after welding it? Sheesh. I think I'm typing in English. :confused3:
   / Just bought first tractor and got ripped off #143
Yes there is a technical reason for grinding the weld. I will post the reason on Wednesday,,,,
:confused:
:confused2:
OK, just kidding!! :laughing:
The reason for grinding is it is a cheap way to do a pretty good quality check of the weld.
Many times, it is easy to lay a bead, which only fuses to one side,,, and not the other.
In many cases, the unfused portion of the weld LOOKS great,, but, it will leak.
99% of the time, even a minor smoothing of the weld bead will present the unfused portion of the weld.
   / Just bought first tractor and got ripped off #144
The welded/built up area becomes stiffer than the surrounding metal causing a stress riser. Grinding the repair to blend will give a more gradual stiffness transition and make it less likely to crack right next to the repair. ... A flap disk followed by a needle scaler peening would be ideal.
   / Just bought first tractor and got ripped off #145
Thank you thank you thank you. :thumbsup:
   / Just bought first tractor and got ripped off #148
Oh man, there's hardly a day that goes by where I don't learn something. I'd hate to not learn something every day. That would be boring.
   / Just bought first tractor and got ripped off #149
Do sent matter take pride in your work or don't do it!!!!.
Corrected.
Doesn't matter. Take pride in your work or don't do it!!!!
   / Just bought first tractor and got ripped off #150
Corrected.
That what I wrote and my phone changed it before I looked. The way a person fixes some thing tells a lot about him.
PALLET OF MISC SUPPLIES (A58374)
PALLET OF MISC...
Kubota R5205 (A57148)
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
(5) 12' GATES (A58374)
AUGER (A58216)
AUGER (A58216)
2864 (A58376)
2864 (A58376)
