JD X310 - no spark
/ JD X310 - no spark #1
ricardo1967
Columbus, IN
2012 JD X310
First time posting, long time reader. Problem at hand: JD X310 cranks, but no spark. Details:
1) 2012 JD X310 bought in Jan/2016 from first owner - in great shape - with ~140 hours.
2) I got carried away while power washing it a couple months ago (using Krud Kutter multi-purpose pressure washer concentrate). Idiotic, I know.
3) While power washing, some water/detergent reached electric components, causing it to self-crank randomly. In panic, immediately suspected it was the ignition switch, so I disconnected the battery.
4) The mower worked fine in the following weeks. I'd disconnect the battery after using it, just to be safe and avoid unintended cranking. After a couple weeks, I got confident and stopped disconnecting the battery. That worked fine for a month or so.
5) Than one day I find the mower in the shed with battery totally drained. So I jump started it to go mowing. It fired up fine, worked for 10 minutes, did a loud back fire and died. It smelled burned plastic (wire or something). It wouldn't crank, all dead. All fuses were good.
6) I found the micro-relay (JD info is confusing, it's either PN 57M9880 or M169838 they're equivalent) visibly burned. I replaced the relay with a generic one (Carquest BWD R4823). This restored cranking, but still no spark.
Model: X310 Tractor
Date of Manufacture: 050212
Product Identification Number: 1M0X310AECM223815
Engine: Kawasaki 603
Family: KAXS.603N4CB
Made of Mgf: 0412
Code: FS600V-AS21-R
E/No: FS600VA43163
Any tip on where to start troubleshooting it? Thanks in advance.
Here is a location for the FS600V engine shop manual.
Down load and save. Look in there for some hints on where to start troubleshoot.
Richard
Richard, thanks a lot for the engine shop manual, good stuff!
/ JD X310 - no spark #4
Not that this is your problem but when the ECU fails you can crank all day and no sparky. At around $73 it worth troubleshooting a little bit though, p/n am141075 (it is a little rectangular box that mounts under the dash).
Thanks for the tip Morrison... however, I could not locate this ECU in my X310. Is it miniscule and integrated with the hour-meter?
I'm a new member here and can't post pictures yet.
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
Linde H35D 4,350lb. Diesel Forklift (A61567)
Linde H35D...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
MASSEY FERGUSON 4607M TRACTOR (A62130)
MASSEY FERGUSON...
