Simple tool box for 2400
/ Simple tool box for 2400 #1
BrittR
Member
North Litlte Rock AR
Case 380B, Branson 2400H, Kubota B7100 HST (sold)
Really like the features packed into my little 2400, but would have liked some tool storage. Quick and easy answer for me was 50cal ammo box which is air/water tight, and a couple fender washers (will prob make a 1" or so stiffening support bar for inside box later). Mounted it using the existing ROPS bolts/washers, plenty of thread left. Painted using Rustoleum red which is pretty close match and decently tough paint. Still figuring out exactly what I want to carry in it since I'm used to my old beater Kubota B7100hst and the 2400 is new. Tools are obvious, fist full of pins, and small cookie tin contains plug kit and small Co2 inflator.
/ Simple tool box for 2400 #2
Looks good. Unfortunately that will not work on a cab model. What I ended up going with is a standard old tool bag located just inside the Rt door (which seldom gets used.)
I'm actually going to move/change it to one across the back of the ROPS once I build an expanded metal insert for the ROPS. Tool bag is a good choice as well.
/ Simple tool box for 2400 #4
Looks good. I bought a little red one from TSC www as I recall. It's the flat version of yours. Mounted it on the back of the slow moving vehicle emblem bracket and just removed the emblem as it was just in the way and I don't need it for two reasons: This is not a road tractor and if it were the hazard warning lights would suffice.
/ Simple tool box for 2400 #5
Good idea! Been looking all over to find a good place to mount something. Never thought of there.
/ Simple tool box for 2400 #6
I used one of the holes that mounted the triangle and drilled out the other.
/ Simple tool box for 2400 #7
Nice box! I did roughly the same thing on mine but I haven't mounted it permanently yet.
/ Simple tool box for 2400 #8
Very cool. Paint looks great, not used to seeing those in red, haha. Any rattles, noises or vibes from the handle?
It vibrates some, but the fender washers spread the load and I'm not too worried about it damaging the box, and as far as noise, I keep a small hand towel on top of all the tools/pins etc there and I don't really notice it above the engine noise
/ Simple tool box for 2400 #10
Mine has a plastic handle, piano hinge, probably 14 ga material and quality latch, all for about $10 plus shipping, in red.
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
