2538 50/100 hour
/ 2538 50/100 hour #1
Oledadger
Member
Western, WI
Mahindra 2538
I changed oil at 50 hours. I am now at 100 and called my dealer for recommend service parts.
Parts he recommended:
only one of the fuel filters (hoping it is the easier one to get to)
1 hydro filter
1 hydraulic filter
gear lube for front axle
oil change
hydraulic/transmission fluid
Said just blow out the air filter, let all fluids drain for a couple hours or more if possible, check all bolts you can and find the grease zerks and you should be good to go. $334 for parts/fluid. He is dropping it off at my house as he has to stop by and do a software update.
Not sure if anyone cares but I know I liked comparing notes to others so I figured I would through my $.02 in the pot.
/ 2538 50/100 hour #2
I liked the ' stop by and do a software update ' part.. :) I did not know they were doing that offsite. Good to know, thanks...!!!!
/ 2538 50/100 hour #3
That's the way it should be. There is no real reason whatsoever to have to haul a tractor into a dealership just to reflash an ECU. It's a super simple procedure that takes only a few minutes to accomplish. Lift hood, plug computer or programming device into the OBDII port, download new code, unplug computer or programmer, close hood, start tractor to see that everything is as it should be and you're DONE.
/ 2538 50/100 hour #4
oledager - where do you buy parts just curious? we keep a large stock on hand for that model of various parts
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2013 Ford F-250 Ext. Cab Pickup Truck (A61568)
2013 Ford F-250...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
UNUSED WOLVERINE TDB-11-66W 66" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
