Mowing Large acreage to finish mow
   / Large acreage to finish mow #11
How you mow does make a big difference. I have dealt with a lot of help getting paid by the hour. I can usually do the same job with the same equipment a lot faster.
He has a 60" Grass Hopper but when he's mowing he's not mowing real fast. Plus there are some trees that he has to work around. I'm going to try and calculate the acreage better but I'm thinking 12-15 gotta be close. It's more of long strips weaving in and out of some buildings trees a couple ponds etc
   / Large acreage to finish mow #13
Can someone explain the concept that makes it worthwhile to maintain and finish mow 12 acres?
Is it a golf course?
   / Large acreage to finish mow #14
I like the way my lawn looks from the street....
483063d1475211953-large-acreage-finish-mow-dsc03088-jpg
   / Large acreage to finish mow #15
Can someone explain the concept that makes it worthwhile to maintain and finish mow 12 acres? Is it a golf course?
It gives a retired guy something to do.
   / Large acreage to finish mow #16
Something is wrong with your mower. It is leaving stripes instead of cutting evenly, like mine.
Bruce
   / Large acreage to finish mow #18
My falling apart Mobile Home looks better with a large well kept and cut front yard.
   / Large acreage to finish mow #19
I mow 8 acres each week, and since it's been so wet this year, sometimes every four or five days. Unfortunately due to a progressively lame right arm I can't drive a zero turn. So I use a diesel X750 JD and it mows beautifully.
If I had more lawn, I would get a Swisher finishing mower and pull that behind me, with a combined swath that would sure cut mowing time.
I have not one but two hard to find Gravely wing mowers, 40 inch mowers that add to the 50 inch mow deck. One of my always want to do projects is to build a rig behind my Gravely that could run both wing mowers, a total of 130 inches, so figure a ten foot cut.
If I were you, and depending upon your budget, I would also look at commercial out front mowers made by JD and Kubota. And I'd sure look for a 72 inch mower if it will fit in all the places you need. Before I mowed 15 acres of lawn, I'd also add a wing mower to it. Yes, mowing lots of acreage gets old, particularly when the heat index hits 110.
You'd better have very few bumps and obstructions to get the acres per hour quoted by many. Few of us run our machinery at the max. I for one can't, can't handle the rougher ride.
I sometimes mow my fields with my LP finish mower, and it mows almost as well as my lawn mower; just leaves a little more residual grass when done. That seven foot mower sure does eat up the lawn, so if you can, go big.
But for just mowing, don't use a tractor; dedicated mowers are usually much better for a finished look.
   / Large acreage to finish mow #20
Kubota makes a 110" mower for their larger(est) front cut mowers ... not sure if it's available in the US.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A58017)
2012 INTERNATIONAL...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2021 Caterpillar 299D3 High Flow Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
