Creeping forward with a shuttle shift
/ Creeping forward with a shuttle shift #1
willysmb
Grand Rapids, MI
Massey 1736
I am buying a tractor soon. I have driven HST's before but don't have much first hand experience with a shuttle shift or power shuttle. Long term I plan to do quite a bit of field work and things where I would prefer to have a shuttle shift. I also plan to snowplow my driveway and other around the house tasks from time to time.
My question is how hard is it to creep forward with a shuttle shift. Lets say I am a foot from my garage door and I want to creep forward that foot to put the FEL down and pull snow back. I have driven plenty of manual transmission vehicles. Would creeping forward that foot be similar to driving a manual transmission vehicle where you just let off the clutch a bit or does a tractor drive differently to where it would be hard to do that.
Thanks
/ Creeping forward with a shuttle shift #2
Thanks
Petty much the same. To inch forward or backward for hooking up a backhoe, FEL etc. have one foot on the clutch and the other on the brake. Lowest gear of course.
/ Creeping forward with a shuttle shift #3
With my M8540 hydraulic shuttle shift, I won't even try something like that; can be done riding the brakes, but not worth trying for me.
/ Creeping forward with a shuttle shift #4
With my tractors of various standard configurations, i could come flying in in any number of gears and then inch up to anything. As long as the brakes work, that is. Just like a car.
/ Creeping forward with a shuttle shift #5
This rubbish of HST being "more precise" is just that; rubbish.
/ Creeping forward with a shuttle shift #6
That's why it's called an "inching pedal". It works great for me.
/ Creeping forward with a shuttle shift #7
Not on our tractors it isn't; we have regular HST, old style crash boxes, synchronized shuttle, non-synchronized shuttle and hydraulic shuttle. Our geared, synch and non synch shuttles can be very precise but not our hydraulic shuttle.
/ Creeping forward with a shuttle shift #8
Bummer. Kind of a poor excuse for a chore tractor that hydraulic shuttle. You can't operate it like a regular clutch tractor when necessary?
/ Creeping forward with a shuttle shift #9
1st gear low range is sllllloooooowwww with my gearing.
/ Creeping forward with a shuttle shift #10
Same with mine. I creep up on stuff all the time. Just part of operating a tractor. But mine is a manual shuttle. Don't see why a hydraulic shuttle would be different but don't know.
gg
/ Creeping forward with a shuttle shift #11
The hydraulic shuttles I have driven could all be operated like a regular clutch tractor. In fact, i am so used to clutching that I did not drive any of them without using the clutch most of the time. I only tinkered with the power reversers...
/ Creeping forward with a shuttle shift #12
If by "hydraulic shuttle" you mean a "power reverser" they have a clutch pedal and can be used with the clutch to inch in either direction.
/ Creeping forward with a shuttle shift #14
Every tractor I have owned can back up to PERFECTLY align a hitch pin, so Idk.
Both of my creeper gear tractors go pretty slow...as slow as that video, and as slow as you want with the clutch. I find no use for creeper gears in my operation.
/ Creeping forward with a shuttle shift #15
That's kinda what I thought. Excepting possibly Kubotas, apparently.
/ Creeping forward with a shuttle shift #17
My power reverser experience is with an m9000 kubota, a 7something and a 6something Deere.
They could all "inch" or even "millimeter" with the clutch.
So far I haven't driven a tractor that couldn't be precise.
So I don't know what all the hoopla is about with the "precision" of HST. Rubbish.
/ Creeping forward with a shuttle shift #18
Mine is a Kubota M8540 and I've spoken with several M95/8540 owners and all the hydraulic clutches on them are the same, very hard to feather under higher RPMs. All of our other tractors have regular clutches ad they are much different. Since there seems to be difference between brands and gear ratios, I'd definitely drive before buying. Since we have several tractor my clutch doesn't bother me, I just use a different one. Our tractor is used regularly by four dofferent operators and we all have the same observations.
/ Creeping forward with a shuttle shift #19
Huh?
The m9000 I drove that was brand new at the time had no trouble transporting round bales; "inching" at times.
I generally inch at low rpms...it helps to have a torquey motor. Higher rpms are harder on clutches.
I don't think Kubotas are known for torque??
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2014 Jeep Grand Cherokee 4X4 SUV (A61574)
2014 Jeep Grand...
