Suggestions for winch mount on trailer
/ Suggestions for winch mount on trailer #1
07ketnec
Peru, IL
John Deere X300
I have a 18' full tilt hydraulic flatbed trailer. I have a winch to install to the front of it. Just looking for ideas to see how people have done it.
I'll send pictures after work, but I was thinking to make a weldment with a standard female receiver hitch and then I would then fab the male portion to the winch.
That way I can take the winch on and off easily and not be exposed to the elements.
Also thought about a full toolbox enclosure with a front door and mount everything inside.
What has everyone else found that works?
/ Suggestions for winch mount on trailer #2
You are describing my exact setup. No pics as I am not home, but will try to remember tonight.
/ Suggestions for winch mount on trailer #3
i bought a mounting plate it was $61 or 62 delivered to me. i have welded a 2" receiver on my GN trailer still need to weld one on my BP.
/ Suggestions for winch mount on trailer #4
I have a 18' full tilt hydraulic flatbed trailer. I have a winch to install to the front of it. Just looking for ideas to see how people have done it. I'll send pictures after work, but I was thinking to make a weldment with a standard female receiver hitch and then I would then fab the male portion to the winch. That way I can take the winch on and off easily and not be exposed to the elements. Also thought about a full toolbox enclosure with a front door and mount everything inside. What has everyone else found that works?
That's how I would do it.
Chris
/ Suggestions for winch mount on trailer #5
I've owned a couple full tilt trailers. The style shown by Terry is a very good idea. I thought of it but IMO a winch mounted to a portable cradle was kind of heavy as I have limited lifting ability in my left arm. I decided to mount mine to the trailer.
The first was a 20'er and I made an angle steel frame in front, mounted a TSC box and installed the winch inside the box. Also in the box is my tilt bed pump which I installed. The trailer was originally a manual pump tilt. (first 3 pics)
My second is a 22'er and I mounted the winch to the deck and tilt bed steel frame then made a cover for it. (second 3 pics)
/ Suggestions for winch mount on trailer #6
Here is my version of a winch mount. Works good, added a wireless remote after the picture was taken.
Thanks! All look like great ideas!
Have any of you noticed issues with leaving it out in the elements?
/ Suggestions for winch mount on trailer #8
i pull mine off and put it in the garage when i'm done, so i can't answer that
/ Suggestions for winch mount on trailer #9
Mine has been out in the elements for 2 years but with the cover on it I've had no problems.
/ Suggestions for winch mount on trailer #10
I cut out a portable plate for mine. The winch and roller are bolted to the plate and the whole thing can be placed over a hitch ball, strapped/chained to a tree (w/e) or shackled to the trailer. I welded a tiedown ring to the center of the trailer and just use a shackle to connect the winch.
/ Suggestions for winch mount on trailer #11
Just for kicks, i think I saw this idea in FARM SHOW magazine. The guy had a beam on the front of the trailer that allowed him to have his winch and winch mounted assembly slide from side to side or stay in the middle. He had places to put a pin or bolt to hold it. His reason for doing it was because he was often dragging up crippled rigs and the ability to move his point of pull made the process go smoother. One of them thar idears that make you go Hmmmmm.
/ Suggestions for winch mount on trailer #12
Here is my setup. Love it. 2 handles, easy to carry and fully self contained. 8000 lbs. Warn winch, mounted inside an old toolbox to a 1/4" plate on the bottom. The "legs" are square tubing that also hold the 2" square tube that slides into the female on the trailer or into a receiver hitch. Pull the pin and it stores on the shelf until next time.
/ Suggestions for winch mount on trailer #13
I welded a female 2" receiver tube to the front of my trailer so a friend could use it to haul home some old cars. He put his winch on a portable mount made just for 2" receivers. I have a toolbox on the front of the trailer, so he put a battery and the winch in there when not in use and just pinned it to the female tube when needed. Worked fine. I'm planning on getting a winch in the near future to haul logs onto the trailer, so that was the main goal. What I'd like to do is add a battery isolator inside the tool box. When the trailer hitch is plugged in, the alternator on the tow vehicle will charge it, but when it draws high amps during a pull, it won't pull current through the smaller hitch wires, or drain the tow vehicle battery.
/ Suggestions for winch mount on trailer #14
My trailer is a short 16' so I needed to mount my winch forward of the bed. I used a drop hitch with a plate welded on to it to bolt on the winch. The winch can be rotated 180* and remounted so that I can use the winch in the receiver in the rear of my vehicle. Last year I mounted the winch in the receiver of a disabled pickup so that we could winch the vehicle out of a back yard to a place that my trailer could access. Then we moved the winch to the trailer then pulled the truck up on to the trailer.
The winch is a Warn 3700 which is small enough to carry easily yet powerful enough to pull vehicles with flat tires. I only put the winch on the trailer when I need it so portability was important to me. The receiver mount system also lets me mount a hitch and ball to the front of the trailer bed so that I can hitch the front of a small trailer with bad bearings or flat tires once I get it up on the bed. A couple of straps at the back and I can haul it home.
Ford 2000 (A64126)
Ford 2000 (A64126)
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
Quick Attach Backing Plate (A65579)
Quick Attach...
Covington TP-66 (A64127)
Covington TP-66...
