A new type of battery?
   / A new type of battery? #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
This is an interesting article about a new discovery of an older unproductive battery technology that has been reexamined.
The 285 milliamp hours per gram storage capacity with 5000 cycles retaining 92 percent of full capacity.
That really grabbed me. 285 milliamp hours per gram is one heck of a lot of capacity. Multiply that by 1000 grams and that is a kilogram. So you would have 285 amp hours of storage in a battery that weight 1 kilogram or 2.2 pounds.. Now that is one he77 of a battery in a small package. If they can make this thing viable at a reasonable cost, that would revolutionize energy storage. I wonder if all of this is true. Anyone care to comment.?
PNNL: News - Unexpected discovery leads to a better battery
Power dense zinc-manganese power unit as cheap as a car battery
   / A new type of battery? #2
"So they added manganese ions to the electrolyte in a new test battery and put the revised battery through another round of tests. This time around, the test battery was able to reach a storage capacity of 285 milliAmpere-hours per gram of manganese oxide over 5,000 cycles, while retaining 92 percent of its initial storage capacity."
I wonder what proportion of battery weight is made up of manganese oxide. ... Also voltage, hence energy, is not provided.​
I knew I was reading that wrong. It was too good to be true. Thanks.
   / A new type of battery? #4
Well, less good. Confused reporting probably. -- The high energy density claim is probably true. For how high, its a waiter I guess.
Well, less good. The high energy density claim is probably true. For how high, its a waiter I guess.
Yeah I am now doubting it is an order of magnitude higher than lead acid like I thought before.
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A57880)
2018 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1998 WABASH TL Wabash National Corporation (A56858)
1998 WABASH TL...
2017 Chevrolet Express 2500 Cargo Van (A55852)
2017 Chevrolet...
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
