Ford 3000 front tires for finish mowing
   / Ford 3000 front tires for finish mowing #1
tlj87
Gold Member
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
I replaced the original front tires on my Ford 3000 6 years ago with a multi-rib implement tire (which is basically what was on it originally). These "new" tires tear up the grass when turning, particularly if its quite wet or quite dry out. Perhaps the old ones did too, when new I'm wondering what my options are? Would an 16" truck tire really make a difference? This is what I current have: IMG_2375.JPG
   / Ford 3000 front tires for finish mowing #2
Originally it probably had a tri-rib or possibly a dual-rib.
I think they would do damage when new also.
Maybe a very gentle all-terrain LT type truck tire? Not confident enough to suggest spending the money though...
It did not, unless they were replaced very soon after purchase.
   / Ford 3000 front tires for finish mowing #4
Or special ordered.
This tractor was designed to be a chore tractor in the AG world. With that intention the front tires need to get a good bite during turns. Takes a lot of pressure off the brakes.
   / Ford 3000 front tires for finish mowing #5
Looked closely at your pic. Rear tires show significNt wear?? Maybe on it's second set of fronts by then?
Nice pic!!!
   / Ford 3000 front tires for finish mowing #6
Keep your present tires an add 200-400 lb of front weight. Then when you turn the wheel, the tractor will turn instead of scuffing up turf.
Looked closely at your pic. Rear tires show significNt wear?? Maybe on it's second set of fronts by then? Nice pic!!!
Original rubber on the rear. Tractor has been on my property since it was 4 years old. It has less than 2700 hrs. I got the tractor with the property in 2009 and knew the previous owner.
This makes sense. I'll have to find a weight bracket and some weights. Slightly concerned about extra weight on soft ground but, I can't be too picky.
Galvanized steel Fence (A55758)
Galvanized steel...
(INOP) JOHN DEERE 670B MOTOR GRADER (A51406)
(INOP) JOHN DEERE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
1991 GMC TOPKICK CHASSIS TRUCK (A54756)
1991 GMC TOPKICK...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
