sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,698
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
This is a picture of an L4300 Kubota off the net and is typical of many earlier models. Replacing the battery on these models looks, and is difficult. When my battery failed yesterday, I learned an easy way to do it that only involves four bolts. That's all.
Before doing anything else, remove the hood side panels. There are two bolts that hold the hood top to the grille assembly. Removes those plus two bolts that are accessed from under the tractor and also hold the grille assy on. Those four bolts gone and the grille assy comes off and the battery is easy access. Mine takes a series 24 battery.
In searching the net after my 13 (!) year OEM Kubota battery finally failed, all I found were confusing attempts at removing the hood or trying to squeeze the battery out. The above method works better and is easier.
