My 2016 M6060
/ My 2016 M6060 #1
No Chrome
Member
Saint Cloud, Florida
2016 Kubota M6060
just delivered on friday:thumbsup:
boy do i have a lot of questions:rolleyes:
/ My 2016 M6060 #2
Welcome aboard!!
Very nice machine! Congratulations. Now, go get it dirty!!
/ My 2016 M6060
hahaha.
actually i had already mowed 10 acres.
i brought it back up to the house just to recheck everything and see if anything was leaking.
i ended up washing and waxing it while my wife stood there just shaking her head.
must be a guy thing...:rolleyes:
/ My 2016 M6060 #5
Congratulations, we love our 12/12 M8540HDC, had it about five years now. The M60s have a bit bigger cabs and better shift linkage, you'll love it.
/ My 2016 M6060 #6
hahaha.
Mine gets an annual wash and wax too.:)
One thing I'll mention if that is in fact an action shot: if you're just mowing, I really like to drop the bucket. I usually leave the loader on, but just removing the bucket improves visibility, improves maneuverability, and reduces front end wear. Give it a try. I leave my bucket and forks on the ground unless I'm using them.
/ My 2016 M6060
Thanks folks.
Yes,that was just a quick pic for my new friends at TBN
/ My 2016 M6060 #10
ya done good, can't go wrong with that set up. is that a 6' hog on back?
/ My 2016 M6060 #12
Nice looking setup!
You may want to consider getting the front Rubber or Chains for your rotary cutter. The rubber or chains will keep alot of the trash from being thrown back up at the rear of the tractor.
Never understood why LP doesn't just at least install the rubber on the front as standard equipment.
/ My 2016 M6060
yes it is.
i know the 6060 can run a much larger mower but we have a pine tree farm so there is a lot of trees to dodge.
i like my cutter tracking behind me and not sticking out on both sides.
i use my smaller massey 1440 for running inside the trees.
/ My 2016 M6060
i do 90% mowing and 10% tree trimming,grapple and bucket work
so heres what i got...
M6060 HDC
8+8
1 rear remote
LP RCF2072 mower with front chains
LA1154 loader with 72" bucket
3rd function valve
Air Ride Seat
Pioneer 200 watt stereo with bluetooth and remote control
heat and A/C
R4 tires
delivered for $41,500.00 out the door.
how did i do?
/ My 2016 M6060 #16
i do 90% mowing and 10% grapple and bucket work
M6060 HDC
8+8
1 rear remote
3rd function valve
Air Ride Seat
heat and A/C
R4 tires
how did i do?
One of those "it depends" things. We got caught with a broke tractor and no time to wait, so we picked one on the lot. If I had time to wait, I would have gotten what you did along with three rear remotes TnT, cast centers defoggers and rear wiper.
I got only two rear remotes with hydraulic top link, bigger than OEM Ag tires, 12/12 hydraulic shuttle. I have an air ride seat base ready to install and we are running the grapple off a rear remote. We pull a 10' Woods DS1260 pull type rotary cutter.
I've got a mix of hills, flat ground, woods and a mix, so my needs are different than yours, so you may well have all you need. I highly recommend a hydraulic top link, I got mine from Brian at Fit Rite.
/ My 2016 M6060 #17
That thing is a BEAST!!!
Very Nice! :thumbsup::thumbsup:
/ My 2016 M6060 #18
Congrats on the new tractor.
A new tractor buyer's "additional options" list should only be limited by their budget. If no budget limitations, check every block!!! :)
/ My 2016 M6060 #19
Agree, I usually drop the whole loader, only takes a couple minutes to take on and off. Way better visibility.
/ My 2016 M6060 #20
Yep. I've brush cut twice with the FEL on. Both were less than 30 minutes.
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A66738)
2020 Ford F-53...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
