Oil & Fuel EMAX22 service video
/ EMAX22 service video #1
Rdr202
Cranston
Mahindra emax22
Made this video showing the 50 hour service. It's far from perfect video but it may show a new tractor owner that the job is not that difficult if they are on the fence about doing the service the self Mahindra eMax22 50 hour service - YouTube
/ EMAX22 service video #4
Great video. It stopped short of how you got to the hydraulic filter. I havent really gotten into this yet but it looks tight with the hoses and the heoght adjustment rod in the way. I asked the dealer and was told to wrestle it out. You have to have a better idea. Thanks for any help
] It actually looks worse than it was. I loosened it with a filter wrench, then I was able to to spin it off with a plastic bag over the filter so as to not have a mess with leaking fluid. There was just enough room to gently get it past the hose and rod. I guess I should have had someone video it while I worked at it. Before you start I would get under tractor and do a walk through as to how you are going to proceed.
/ EMAX22 service video #6
I was told by the dealer to remove the rod, or the seat, or cut an access panel to get it out. That didn't make sense to me. Thanks for the help. I will give it a shot
/ EMAX22 service video #7
Thank you so much. I'm thinking of doing this service now at 42 hours on my 2015 EMAX22G before winter snow sets in and I'm scraping snow.
Check the top weld on the center hydraulic cylinder mount on your loader bucket. The weld on mine has cracked and a warranty claim submitted.
I forgot to mention before removing filter I cleaned it before I loosened it and put a clean plastic bag around the filter. This way if I couldn't get it out I could put it back on if needed.
My tractor was made in 2015 what year was yours made?
/ EMAX22 service video #9
I bought this in Sept. 2014. I am pretty sure they are the same
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
832754 (A61166)
832754 (A61166)
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 4x4...
