What feature would you like to see?
   / What feature would you like to see? #1
Bluesteel
Gold Member
Illinois
LS MT 357HC
Many post a certain feature they would like to see on their tractor. I recently read a indicator light when the 4 wheel drive is engaged, a clock not on the stereo, etc. I would like to see a little larger fuel tank. Even though the tractor is fairly easy on fuel it would be nice to not have to fill it so often, especially from a can. After several hours of mowing pasture the last couple days I thought a cooled seat would be nice. It would probably be very costly and possibly not doable due to the air unit located in the roof. My wife's Tahoe has heated and cooled seats. The few times I drive it the cooled seat is nice. I'm thinking about trying one of those cooling pads but I think if you are on them a while they end up being the same temp as you.
So what would you like to see on your tractor it currently doesn't have?
   / What feature would you like to see? #2
LED lighting front and back on ROPS,heavy duty good size tool box.
   / What feature would you like to see? #3
Chain box, tool box, pin box, glove box, hat box, coat box, lunch box.
Bruce
Bruce
So, you would like some type of box.:laughing:
   / What feature would you like to see? #5
You already mentioned the 4wd dash light, and a Digital volt meter are my biggest items. As Bruce mentioned a chain box would be a nice factory option.
I already installed F&R LED light bars, reflective tape, small tool / pin box and flashing strobes
I've already located and ordered a long lever micro switch for the 4WD linkage but not the type of 4wd light I want to install in the dash. Still looking for the right LED volt meter for in dash. When I find what I want I'll post pics of the installs.
Past couple days I've been spreading 22 tons of gravel in the driveway. With outside temps in the mid 80's I about froze my butt off with the A/C on. I turned it down and actually got out a few times to warm up. That A/C works great.
   / What feature would you like to see? #6
A integrated "quick hitch" on the 3 point linkage. Ken Sweet
   / What feature would you like to see? #7
Self leveling loaders on the XR series, audible parking brake warning (when putting SS lever F/R or depressing HST pedal), and a factory thumb option for the backhoe. Finally, a 540E setting for the PTO on 50+ HP engines for running RFMs and other lighter duty implements.
   / What feature would you like to see? #8
Self leveling loader would be a great feature. Fast dump on the XR series loader would be nice.
My XR does have a dash light and an audible parking brake warning if you try to move the HST with brake on. It also reminds you to apply the brake if you get off the seat with motor running. If you are not in the seat and reach in and push an HST pedal with the brake on it will stall.
All good suggestions here.
   / What feature would you like to see? #9
How about one of those old steel seats with an old pillow or grain sack If you want cooling, take away the pillow!
I would like to see the demise of the 3ph in favor of a better (faster) but Universal system.
   / What feature would you like to see? #10
Good to hear. On the XU there's a dim ((P)) light that hides behind the steering wheel and no audible. The brake doesn't slow it down much, so it's easy to run off without noticing. Luckily I never got too far along...
OT: Not familiar with wet brakes -- is there a wearable pad or lining that must be replaced to restore braking power after lots of use (or misuse) ? Also, do you have to split the back end of the tractor to get to them, or do they have a separate housing?
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
2003 Big Tex 10PI...
Adams 16T Tender Body (A56438)
Adams 16T Tender...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
