Picked Up My LS XR3135HC Pictures
   / Picked Up My LS XR3135HC Pictures #11
Re: Picked Up My LS XR3135HC Additional Pictures
Great pics Mike. In comparison to my 3037HC I see a few changes in the cab. (I know you have an LS engine)
1) Different seat
2) Different dash display
3) Different switches on right console
4) No 3rd remote location spot
5) I think you have Auto PTO switch, I don't
6) These things I added. I added F&R cameras, extra LED flood lights F&R, flashing strobes F&R, Reflective tape all around, outside mirrors relocated, Grab hooks welded and tow hooks bolted on bucket, small tool box on back, expanded metal installed in brush guard and a low profile strobe light on top of cab.
I'm sure all you new owners will make changes and additions as you see fit.
1) Different seat
Mine has the switches under the column, horn, flasher, aux headlights, my degen switch is where your beacon is, and side switches are different. I see the seat being different, my arms have adjustable height and covering is different. Because I have F/R worklights this thing has more front lights than a semi. Hi/lo beam headlights and aux headlight and of course worklights. Should be interesting to see how it illuminates at night. The one thing I miss from my JD is the inside light would come on when you opened the door, the LS doesn't.
The dash display doesn't light up all the symbols except when you first turn it on, otherwise it is normal prior to start, as seen in my pics.
   / Picked Up My LS XR3135HC Pictures #13
Congrats on the new ride!
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED (1) 3500# IDLER DROP AXLE (A54756)
UNUSED (1) 3500#...
Miller Bobcat 250 Diesel Welder (A54865)
Miller Bobcat 250...
UNUSED FUTURE PG72 - 72" GRAPPLE BUCKET (A54757)
UNUSED FUTURE PG72...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
