Buying used (250/2500), what to avoid (engine/trans known issues)
   / Buying used (250/2500), what to avoid (engine/trans known issues) #31
Being a past owner of a 2004 with a Cummins, I'm betting his overhead actually says 25 mpg, mine said 21 all the time but I really got 14 to 16 mpg. I will say his combinations of 2wd and the manual transmission has a reputation of hauling down really good fuel mileage. 20 mpg or a little better is possible.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #32
Yeah, I'd believe 20 with a 2wd six speed. I'd probably even believe 22 going 60 on the highway. 25 though is pretty hard to believe. Maybe on the display, but not in real life.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #33
Oh c'mon, you really expect us to believe that you're getting over 25 mpg with a 3/4 ton truck?? Really??
I used to get 22 mpg,s on the highway with my 2004 dodge 3/4 ton cummins 5.9 diesel driving 55-65 mph.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #34
Yep, I'd believe that. 25 mpg is more than 10% better than that.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #35
i believe him.... 2wd 6 speed is a great truck for getting good fuel economy, dad had a 04 2wd auto cummins that would do 22-23 without any trouble, he now has a 96 PSD 2wd auto that will do 26 without any trouble, i have a 94 PSD 4x4, 5 speed that i have seen 24.8 out of once and routinely does 21.6-22.4.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #36
Around here you'd be stuck with a gas truck at that budget. Any decent diesel is bringing 25k or better. You definitely need a 3/4 or 1 ton. A 5.4 Ford has adequate power as long as you don't expect to go hot roding around while loaded. The v10 is way stronger though. A buddy has a Ford V10 and a Chevy 6.0 and he says the Ford will pass anything except a gas station. In reality it can't run with a diesel, but he has less than 1/4 as much in that truck VS a comparable diesel truck.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #37
My best full tank to empty on my 03 3500 4x4 Quad cab with nv5600 was 24.4 MPG- hand calculated.
But the over head was reading over 28 mpg... that was all hiway/interstate.
about 17 pulling the 10 k fiver with a lite load and as low as 13.5 with 10 k load + trailer weight on local roads,
Woops- that is unloaded one way- loaded the other and repeat till re fill So the #s would be lower for fully loaded the whole trip
unloaded short- just town and back (15 miles total) for a whole tank nets about 18.5 mpg
Since the owner has only had his 2500 ram for 3 weeks he may have trusted the overhead display,
have not heard of any 2007 and older rams having accurate fuel mileage displays- and in every case I have heard of they always give (over optimistic) mileage
   / Buying used (250/2500), what to avoid (engine/trans known issues) #38
That's about 9k worth of trailer and cargo: hauled a good 60+ miles, even through Seattle. 23 year old 7.3L IDI F250 with approximately 250k miles. Bought the truck about 3 years ago for $2,500. Trailer was also $2,500.
Truck will sit for months on end (it's a farm truck). No matter what, glow plug it and it fires off. No electronics (other than a $70 GP controller). 5spd with clutch that's only got about 35k miles on it. If I need something more powerful I'll go rent it.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #39
Got a different question I have a Chevy 01 4th with the 6.0 gas engine. I would like to take that engine out and put a 5.9 Cummings 1st generation in how much work will it be? . I. Thing both axles will be strong enough the only question is the engine and tyranny to get together.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #40
Google is your friend, many swaps like that done and documented, easy to do a search and find loads of info...
2019 JOHN DEERE 325G SKID STEER (A50458)
2019 JOHN DEERE...
40FT Shipping Container (A48837)
40FT Shipping...
ECHO CS-4920 GAS CHAINSAW (A50460)
ECHO CS-4920 GAS...
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
FLOWTRONEX SYRINGE FAN (A50460)
FLOWTRONEX SYRINGE...
(1) HD 24ft Free Standing Corral Panel (A48837)
(1) HD 24ft Free...
