JD 3720 CUTS HST Sluggish
   / JD 3720 CUTS HST Sluggish #1
Beltzington
Appling, Georgia
JD 3720
Yesterday while finishing up some mowing I noticed starting in both forward and reverse seemed to require more pedal than normal. At first I thought I had left the parking brake on as I occasionally do but that was not the case. Once the tractor starts moving operating speeds seem normal. Hydraulic fluid is at the full mark and looks clean and does not smell burnt. I am still 100-hours from the transmission fluid and filter service interval and 300 hours from replacing the inline hydraulic filter.
Any recommendations?
   / JD 3720 CUTS HST Sluggish #2
Might be time to service the filter and clean the screen.
What parts cleaning fluid do folks use for hydraulic components?
   / JD 3720 CUTS HST Sluggish #4
Gasoline is what I use. With care, of course. ;)
   / JD 3720 CUTS HST Sluggish #5
Motion match happened to get changed?
I'm the only one who drives it and it has a good battery so I do not see how it would have changed but something I should check. Unfortunately I don't recall where I had it set, can't recall important details since the concussion :)
Thanks
   / JD 3720 CUTS HST Sluggish #7
I think you'll find directions in your operators manual under the "operating" section on how to change the "motion match" settings using the display mode switch and the turn signal switch if you don't have the optional switch on the fender.
The settings are from 1~9, One being neck jerking to 9 being "I think I can move but I'm not sure when"
Keep in mind, it's a #$&* computer that only understands 0's and 1's and you're a rational, intelligent human being trying to talk to it. Keep the faith. I chose #2. Seems right for me.
   / JD 3720 CUTS HST Sluggish #8
I have to look at mine because when idling slow sometimes the tractor won't move until I rev it up. Thanks for the input; it is something I never heard of and had the tractor 5 years,
   / JD 3720 CUTS HST Sluggish #9
Mine is dead at idle (B range) too but it snaps to life at 14 or 1500. It might s-l-o-w-l-y move if it's sitting on the cement floor at idle but certainly not out in the yard. I wouldn't think selecting 1 in motion match will help that. Just always figured that was a function of oil flow and pressure. (or lack of)
   / JD 3720 CUTS HST Sluggish #10
Oldtink
Maybe, but my 4300 HST is responsive to forward and reverse pedal at any rpm, including idle. just sayin...
   / JD 3720 CUTS HST Sluggish #11
Oldtink
All three of my hst tractors are responsive at idle, increasing the rpms certainly increases the travel speeds though.
   / JD 3720 CUTS HST Sluggish #12
I could drive any of my HST tractors at idle, but they work much better at higher RPMs. My F2560 will drive at idle, but it's unable to lift the deck which is hydraulic.
Update - I finally was able to adjust the Motion Match (MM) setting, had to order and replace my broken turn signal rocker switch which I never use but it is how the you raise or lower the MM settings if your tractor does not have a dedicated MM switch. Kind of hard to explain but the MM settings do not really effect how fast the tractor moves but how abruptly it starts and stops moving. At idle with MM set to 1 (most aggressive) it still seems sluggish at idle. I spoke with a very experienced mechanic and he said this is not uncommon as the hydro pump and valves will loose efficiency over time and more RPMs will be required for the tractor to move as it did when new. He also said not to worry about it as it will likely be 1000+ more hours before I would need to start considering rebuilding or replacing the pumps.
   / JD 3720 CUTS HST Sluggish #14
I think another experienced service man is in order.
I have 650 hours on my 3720 and everything was working great then all of a sudden the tractor would barely move at idle and wouldn't jump to life until 14-1500 RPM then works fine at higher RPMs. But if driving along at high RPMs and bump it to 1000 RPMs the tractor would slow way down, much more than before, almost to a crawl.
I would think if the pump was going bad it would go bad progressively, but seems coincidental that yours seems to act the same as mine, unless I read something wrong.
I stopped into a JD dealer here and got a lot of head scratching but one mechanic said I should may try cleaning the inline hydraulics filter. It has another 100 hours to go before I think I should but as soon as I get a couple gallons of oil I will try that. He said there might be something in the inline filter. He also said I should drain the oil and fill with diesel and run it a while with that in. I really hate to do that, but am beside myself trying to figure this out.
The tractors speed is to hard to regulate now unless you want it wide open, or at least faster than 1500 RPM, but I need to go very slow and idling in some applications.
   / JD 3720 CUTS HST Sluggish #15
Same thing with my 3720 but not my 3120. Same thing bump to 1500 works fine at idle just about inop. Been like this since around 150 hrs. I assumed that the smaller engine without the turbo kicking in was the issue since the bigger displacement 3120 was fine. But the in line filter=check valve might be the ticket. In 30 hrs I will know and share answer.
   / JD 3720 CUTS HST Sluggish #16
You can clean the inline filter without loosing any fluid.
   / JD 3720 CUTS HST Sluggish #17
I was told by a mechanic at a dealership my problem and he said to clean the inline strainer but all the fluid would be lost. I just need to ask, "Are you sure," and if so is there a particular method to it other than to unscrew it and take it off?
   / JD 3720 CUTS HST Sluggish #18
That's surprising. I cleaned my inline filter on the 3520 and didn't loose more than a cup of oil the whole time the lines were disconnected while I sprayed off the element. BTW the filter was spotless upon disassembly at approximately 500 hours and is the first time I inspected it. It of course didn't change anything as far as not moving at idle.... 100_4734.jpg
just say en
   / JD 3720 CUTS HST Sluggish #19
That's surprising. I cleaned my inline filter on the 3520 and didn't loose more than a cup of oil the whole time the lines were disconnected while I sprayed off the element. BTW the filter was spotless upon disassembly at approximately 500 hours and is the first time I inspected it. It of course didn't change anything as far as not moving at idle.... View attachment 487750
just say en
Did you change that think while the transaxle was still full of fluid?
It does sound like a plan though. I'll try that first. The dealer must have gotten his wires crossed somehow.
   / JD 3720 CUTS HST Sluggish #20
You might would loose all your fluid if your tractor is upside down. The filter is on the side of the engine. The cartridge filter in the sump under the tractor.
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
XCMG CV83PD (A53317)
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Year: 2019 Make: Jeep Model: Grand Cherokee Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A59231)
Year: 2019 Make...
