Trenching - worth trying for a novice?
   / Trenching - worth trying for a novice? #31
IF you are crossing an existing line.....hand dig anything within 2 feet. DONT trust what they tell you depth wise. Things on the surface can change, or the contractors doing the job might not have done it to spec.
Let it be located. Hand dig within 2'. If you hit it outside of that boundary.....its their problem. IF you hit it within, you will get a hefty repair bill
If you hit 400 amp service inside or outside of the boundary you are going to have a hefty hospital/funeral bill.
   / Trenching - worth trying for a novice? #32
The guy operating the trencher for the gas company said that he had cut a 7200 volt line. He said it welded the chain on the trencher to the bar, but he didn't get shocked.
   / Trenching - worth trying for a novice? #33
What will happen in any particular case of cutting a power line will depend on a lot of variables. Some people have died from driving a drywall screw into 120 volts, and some people have walked away from encounters with thousands of volts. To think for even a second that it's not dangerous because you know of a case where it did not cause injury is just stupid.
The one thing that is guaranteed is that you will be better off not cutting a power line.
   / Trenching - worth trying for a novice? #34
I trenched in 2000' of 2" water line and 1500' of electric with a ride on trenched. I'd never been on one before. Of course it didn't have to be inspected or anything. It hasn't frozen or came apart, so I guess I did OK.
   / Trenching - worth trying for a novice? #35
Any updates?
Any updates?
Nothing yet -except I decided to let my driveway guy do the trenching. His rates came in quite reasonable and he has more experience/time than I do. By the time I rented the equipment paid retail for pipes, etc I was looking at close to $2,000 and he's going to do it for around $3600.
   / Trenching - worth trying for a novice? #37
That sounds about right for piece of mind... and being able to watch from the porch :)
   / Trenching - worth trying for a novice? #38
Is that all three utilities? GAs, water, and electric?
As per your quotes in the first post of this thread.....
Water would have cost you $3900 turn key
Gas at $1680 turn key
Electric at $560 and you still had to buy wire.
If you got everything done 100% for $3600, thats awesome.
What did you decide on the drive configuration?
   / Trenching - worth trying for a novice? #39
I got a brother lives up your way, north of sunbury.
Yeah my 3rd guy came in a lot lower 👍
For the driveway I think I'm going to go without the geofabric, except I might put some down around one section where I'm putting in a small culvert
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
2014 Ford F-250 Ext. Cab Pickup Truck (A55852)
2014 Ford F-250...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
