HST Oil Change: Fact or Fiction?
/ HST Oil Change: Fact or Fiction? #41
Yes, I'm sure that's what he was thinking but you have bigger problems than a 400hr oil change if you have water leaking into your hydraulics.
It's not so much water leaking in, on a newer tractor, although that can be a concern.
There is a possibility of condensation accumulating in there, under certain conditions.
/ HST Oil Change: Fact or Fiction? #42
It's not so much water leaking in, on a newer tractor, although that can be a concern. There is a possibility of condensation accumulating in there, under certain conditions.
But condensation can occur in the barn too unless it's heated
/ HST Oil Change: Fact or Fiction? #44
True that. Pretty common on older tractors, not so common on new equipment.
/ HST Oil Change: Fact or Fiction? #45
Yes it can, but not to the extent it could, or would, outside.
Yeah, especially here in the midwest. The temperature of the metal on the machine may change several degrees many times in a day of unsettled weather due to sunshine changes alone.
My old all metal machine shed proves that during a partly cloudy day while my machinery is protected in it's shade.
/ HST Oil Change: Fact or Fiction? #46
I always change the fluid because the manufacturer says so. There are examples where in the past manufactures have said, oh you don't need to change this fluid because it is sealed and then had to change that recommendation because it caused failures. The fluid does get contamination from wet clutches (PTO) brakes and most tractors use the HST fluid in any implements you hook to. Not to mention the gears and bearings have a shearing action which breaks down the oil.
/ HST Oil Change: Fact or Fiction? #47
Does anyone worry about cross over contamination with the implements that share the same fluid, grapples, backhoes, etc . . . ., anything with a hydraulic cylinder, - that fluid will be going through your transmission with HST.
/ HST Oil Change: Fact or Fiction? #48
I don't rent or borrow implements nor do I loan mine out so the fluid is all the same.
/ HST Oil Change: Fact or Fiction? #49
That's the least of your worries. The sun ruins everything it touches. The building I keep my tractor in leaks pretty bad, but at least it offers UV protection.
/ HST Oil Change: Fact or Fiction? #50
Other than parking, I rarely use the brakes on my B26 so I wouldn't worry too much about that. I really doubt that a properly stored (inside enclosed structure) tractor would ever wear out the oil or additives in hydraulic oil. There is not outside contamination on tractors with no remote outlets and if you don't use equipment from neighbors, even with remotes there is not much likelihood of cross contamination of oil. That being said, the changing of fluids in most folks CUTs every 400 hours or so is not that great of an expense that it couldn't be done on the recommended interval especially if doing it yourself so the only expense is the materials used.
Personally I put maybe 75 hours per year on my B26 so an oil change every 5 years or so is not going to break the bank.
Yet many mfg's state to change oil every xxx hours or by a calendar schedule such as annually.
And many here on TBN have advised others to be sure to change their oils annually, usually with the comment "fluid is cheap compared to repair".
Last used vehicle purchased was a GM product.
Had all fluids changed* including transmission fluid mainly for assurance and also to see any contaminants.
Big surprise to me was no provisions were there to drain the transmission other than removing the pan.<snip>
Both my 7.3L Fords require dropping the pan to change transmission fluid.
Like I keep writing, Trust but verify. If it's out of warranty period get an UOA and know what is happening.
/ HST Oil Change: Fact or Fiction? #51
Mine were never changed religiously.
But, they did get the pan dropped, or drained, and 4 quarts of fresh fluid put in on occasion.
My new van, doesn't have a transmission dipstick, and insists no service before 100,000 miles!?
My van didn't come with a dipstick either - it's considered a service tool, available from Dodge/Freightliner/Mercedes.
The transmission has two Hall Effect sensors (magnets) on a plastic circuit plate to calculate the speed of the input shaft. The magnets on these sensors are prone to picking up ferrous wear metal that can cause the transmission to malfunction, throw codes, and go into "limp-home mode".
In order to clean them off you have to drop the pan and the valve body.
Before this issue was identified, dealers were replacing quite transmissions as "failed" when they probably weren't.
/ HST Oil Change: Fact or Fiction? #52
Yes. I mentioned that earlier as a contamination issue. As well as dirty quick couplers.
Countrybumpkin mentioned using starting fluid for a cleaner which I thought was a great idea!!!
/ HST Oil Change: Fact or Fiction? #53
Reminds me of my $350 furnace blower motor, that failed early.
The first one was warranty.
When it happened the second time, on my dime, I looked at the circuit board attached to the motor, and found a burnt part.
After doing some research, I discovered this part, a thermister, fails on these all the time, and is not serviced.
They just sell you a new motor, for $350 plus labor.
I found the thermister online, at an electronic supply store, for $3.50.
I keep them in stock now.
/ HST Oil Change: Fact or Fiction? #54
When my new tractor was delivered the guy that delivered it was the service manager I asked about my othe things that the hyd hooked up to and he said just hook up and go. I stll have not done this because I am afraid of mixing new fluid with old. I have a couple of thing with 4 inch dia cylinders 24 inch stroke and they hold a lot of oil. I think I am going to take the lines off and drain them and lines also then hook up to the tractor. Anyone have any other ideas? I like the idea about using starting fluid also
/ HST Oil Change: Fact or Fiction? #55
Virtually nobody does that. No harm but certainly will take some time and create a bit of a mess.
Do you also steam clean the interior of your car engine each time you change the oil? There will always be a little "cross contamination" but that is what filters are for.
/ HST Oil Change: Fact or Fiction? #56
To get a good dump you'll have to remove the quick couplers on both hoses and cycle the cylinder in to complete collapse and out to complete extension a couple time. If you can do that without squirting oil all over yourself or your equipment you are better than I...... :)
/ HST Oil Change: Fact or Fiction? #57
You can use a rubber tipped blow gun with, low pressure compressed air, to actuate the cylinders, after taking the hoses loose.
It will empty them, and blow oil all over the place. :D If you're careful, you can catch most of it. That's what we do before disassembling them, to get the oil out.
How about, if you wait until you are ready to do your 50 hour, (assuming you will be doing one), hook all them up, and cycle them, right before you drain the transmission?
/ HST Oil Change: Fact or Fiction? #58
This idea has a great deal of merit.
Just cycle the cylinders several times on with each piece of equipment attached. Then change the hydraulic oil immediately and realize that you have done a great job that likely no body else would have done.
If you are OCD, then do the whole process again in 100 hours and you'll have everything 99% flushed. The hydraulic fluid in the implements will never need to be serviced again.
As an example, my '14 Honda Odyssey has dumb transmission that can only be drained about 30%. The required service is to drain and top off, drive for a couple of days, drain again, drive again, and finally do a third drain and fill. Supposed to be good for 90K miles, I believe.
/ HST Oil Change: Fact or Fiction? #59
That would only mean that the dirtiest fluid (that which is still in the transmission) would be cycled into the implements, some of which would actually contain cleaner than average fluid if they haven't been used in a while.
Keep it simple.
/ HST Oil Change: Fact or Fiction? #60
Keep it simple.
If he does it right at 50 hours, how "dirty" can the fluid be, it's still new???"
Mine was as clean as what I put back in.
There is far too much obsessing over oil.
Change it, don't change it, it's going to be alright, either way.
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2001 Peterbilt (A60352)
2001 Peterbilt...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
