foton 404 3pt wont lift
   / foton 404 3pt wont lift #1
dongross
tyner ky
foton 404
after replacing a seal in the hydraulic pump of my 06 foton 404 loader works fine but the 3pt lift wont work it was up when I replaced the pump and worked fine after I replaced the pump I lowered it now it wont raise anyone have that problem be4
   / foton 404 3pt wont lift #2
Yep. I had a line hooked up wrong so it was by-passing in to tank.
only lines I took loose were on the pump and they will only bolt up one way thanks
I took the high pressure line that hooked to the remote hydraulics hooked it straight to the inlet line of the 3ph still wont work sure it the correct line on the 3ph seting in the seat line on the right of the tank that bolts up with 2 bolts ?
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
