Harbor Freight Threadlock equal Loctite brand?
/ Harbor Freight Threadlock equal Loctite brand? #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Has anyone done any testing between these two "competitors"? Loctite is $11, HF is $1.99.
Somebody must have bolted something down with Harbor Freight threadlock, then unscrewed after it's cured, and noted whether holds like Loctite. Right? :thumbsup:
Has anyone done any ACTUAL comparison? I'm at a stage where all my loctites are either empty or dried up; it's time to get more. It kinda p***es me off how you spend so much for Loctite and their bottles leak all over the shelf.
So do I spend $6 or $33?
/ Harbor Freight Threadlock equal Loctite brand? #2
I've used HF's brand medium strength and haven't had anything come undone
/ Harbor Freight Threadlock equal Loctite brand? #3
In a pinch I've used Elmer's glue. I haven't had that come apart either.
/ Harbor Freight Threadlock equal Loctite brand? #4
I know at one time it said made in the USA on the back of the bottle... I have not picked any up in a few years... But it has worked fine for my use... I have not tested it will the real Loctite brand... But you can't beat the price...
/ Harbor Freight Threadlock equal Loctite brand? #5
I have a 36 ml bottle of Permatex blue thread locker. Bought it eight years ago - around $24 dollars. I haven't used half of it yet - so at that rate of use its pretty inexpensive.
In a pinch I've used Gorilla glue & super glue - Gorilla glue is better. Once you break the nut - using super glue - you can unthread the nut the remainder of the way by hand. Gorilla glue - like Locktite - provides substantial "drag" even after the nut is broken loose.
I've tightened more bolts than anybody can count with no locker at all and can usually tell by looking at the joint whether it needs a threadlocker. I'm still interested in a direct one-to-one comparison of the stuff, and thought someone here has tested them. You can tell when you loosen the bolt if the locker works the same.
Have employees who go buy a new $25 bottle every time they lose the old one or it runs out in the toolbox with the cap off. I don't get 16 years per bottle, its probably 1 year. Just curious about a more sensible perfume (you might call it) and less concerned about the brand. ........if I could get an assurance it performs. Agreed that almost anything on the threads can work, but for some items, people expect to see blue or red. Interesting note about the superglue!
/ Harbor Freight Threadlock equal Loctite brand? #7
I don't or can't differentiate between those bolts that do or don't need the "blue goo". I just use the stuff on them all. Mayhaps - part of the reason my bottle lasts so long - I keep it in the pantry, in the house where it doesn't get knocked down or ground around in my tool box. Like has been said - the stuff isn't cheap and does nobody any good spread all over the bottom of a toolbox.
/ Harbor Freight Threadlock equal Loctite brand? #8
Like the smoked sausage industry, it's likely made by either Permatex or Loctite and simply packaged in a HF labeled bottle.
I used to work at an Eckrich smoked sausage factory. We'd make the stuff, run half an order through a packaging machine and after so many cases change the film from Eckrich to Swift or Armour and run the rest of the order out. All the same sausage, different name on the package.
/ Harbor Freight Threadlock equal Loctite brand? #9
There is a user statement in post #2.
/ Harbor Freight Threadlock equal Loctite brand? #10
Quote:
'We'd make the stuff, run half an order through a packaging machine and after so many cases change the film from Eckrich to Swift or Armour and run the rest of the order out. All the same sausage, different name on the package. '
That is the same with a lot of commodities, food included.
Often the Mass merchandiser negotiates the price to exclude the advertising and warranty content of a given brand name product and support that portion under their own budgets.
Basically it is win/win for both parties.
The one gets extra volume and the other gets private label.
Very common in food stuffs and also in the power tool industry (air and electric) Stanley and Dewalt are good examples.
MTD is another with snow blowers mowers etc.
Problem, however, with mechanical s and tools are always the minor variances in components and part number non cross reference.
Few years back a friend went to China on a buying trip and reported seeing air tools coming off of the line with brand name changes every 30 mins or so without any different component changes. (think SnapOn, Harbor freight, Sears, Mac, DeWalt, Stanley etc)
/ Harbor Freight Threadlock equal Loctite brand? #11
I've heard nail polish works pretty good too. Haven't proceed it lately, but there's bound to be a discount brand at a decent price. Nice applicator too.
/ Harbor Freight Threadlock equal Loctite brand? #12
I've used nail polish, it does work but I'd opt for the real stuff if there was a critical issue in a contaminate environment, like fuel or oil mist or vapor. Nice thing about polish is that you can usually beg a bottle off a female acquaintance who doesn't like the color and was going to pitch it anyway.
/ Harbor Freight Threadlock equal Loctite brand? #13
To address the original question some reviews at HF compare them.
I have a friend that works for a glue manufacturer. They make nothing in their name but many of there products you've heard of by major brands. Some are the same products for different labels. If I see him this weekend I'll ask him what he knows about these products.
/ Harbor Freight Threadlock equal Loctite brand? #14
15 minute quick dry inexpensive spray paint. Holds good, will loosen when needed with a little ump and you know if you missed a nut. Spray it after tightening the nut. Might not work on a bolt threaded into a hole though.
I've used the red HF and it seems to work just as good as any.
/ Harbor Freight Threadlock equal Loctite brand? #15
Next you'll tell me that gasoline at different stations comes from the same trucks. :D
/ Harbor Freight Threadlock equal Loctite brand? #16
My approximately 30 year old axe has something that appears similar to dried and expanded Gorilla Glue oozing out from between the head and the handle. Coincidentally, I just concluded that it might be a predicessor to Gorilla Glue yesterday. I don't think GG was available until more recently.
/ Harbor Freight Threadlock equal Loctite brand? #17
I don't care who makes it but my discovery of threadlock was a life changing experience.
/ Harbor Freight Threadlock equal Loctite brand? #18
The Loctite I use is in a tube and is dispensed like lipstick. Never a mess. I never tried the harbor freight stuff.
Basically you have to just gum up the works a little. But I like that the blue has a known "release difficulty." And the red is more difficult, but they are both a "known" difficult.
Sounds like I just have to just test it myself, see if I like it. Will read the HF reviews, I forgot about them. Often there's a lot of them & some sound credible & experienced.
/ Harbor Freight Threadlock equal Loctite brand? #20
On old trick!
Basically nail polish is lacquer so it also fast dries.
Some glues, like Gorilla glue, probably would do in a pinch as well.
For a stronger lock you can also use epoxy, the 2 part mix kind. I observe that they often us epoxy in threaded air tool fittings as well.
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
213064 (A64276)
213064 (A64276)
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
