Comparison Help Me Decide Narrowed Down to LS or Kioti
/ Help Me Decide Narrowed Down to LS or Kioti #1
blb078
Wentzville, MO
LS 4150HC
So I've been going back/forth for a while now and have my tractor choices narrowed down to the final 2(4 actually). A LS xr4145hc, xr4150hc or Kioti nx4510hc or 5010hc. I'm more than likely going with a 50hp but what I can't decide on is which 50hp tractor. I'm getting tractor, loader, backhoe, and a few minor cab options. The kioti deal has given me his bottom dollar once he found out I was looking at LS. For a nx5010hc w/backhoe 12" bucket, 3rd function, 2 rear remotes, bh pads he's at $41,400 and that's as low as he can go. The LS dealer for the 4150hc, backhoe(not sure if his price included a bucket), loader, comes with 2 rear remotes, and wr long 3rd function installed is at $36,600, that was just his first price he gave me and we haven't talked about any offer or anything so I may be able to get another 1-2k lower "possibly". LS dealer is about 15 min away(also a NH dealer 15min the other way in case I can use any NH parts), kioti dealer is just over an hour away. Both dealers have been around for a long time, the kioti dealer has been selling kioti's for about 15 years I think. The LS dealer while being around for like 50 years has only been selling LS for just over a year(they've also been selling mahindra for 15 or so years). I like both dealers and the distance of the kioti dealer isn't to much of a concern.
Here is where I'm hung up though. Obviously the LS is cheaper and has a longer warranty. What I like about the kioti is the loader lifts higher and I do like the ergonomics of the cab layout with the pto switch and throttle being on the right side, it also has auto pto. The LS I like the instrument panel better and the seat has 2 armrests vs 1 in the Kioti. But the loader doesn't lift as high by a little over a foot. The pto switch is also to the right of the steering wheel along with the throttle which is common on a lot but not as ergonomically nice as the kioti, and no auto pto. The BH capabilties on the LS isn't as good as the kioti either. The LS is a little smaller in dimensions which I do like for being in the woods and stuff. The biggest thing that is holding me back is the loader lift height on the LS, if that was higher I would already have signed the paper work.
About what I'll be doing. I have just over 13 acres with about 1.5 acres cleared(maybe to much tractor but the deere and kubota 30hp range cab tractors w/bh where more than these two 50hp which is why I'm at a 50hp, spending less and getting more). I'm building a house on it as we speak, just about to be under roof this week. So I do have a lot of cleanup for that, landscaping and yard that will need to go in. Clearing maybe another half acre or so over the next year or two, maybe even putting in a small 1/6 acre pond and some basic clean up, grass cutting(when grass is there on the 1.5 acre portion) and maintaining of the 13 acres. The wooded part of it is pretty thick with a lot of pines on about 7 acres worth of it. Easy to push down because they are so thick in quantity/close together and not big roots but still a lot of them.
So there is my situation, I keep going back to the loader height of the LS though. As I stated if it had a max height of what the most other 40-50hp tractors have I would already be buying. The ergonomics of the kioti is also something I like and it's probably the 2nd reason why I haven't pulled the trigger yet completely on the LS. Right now it's about a 5k difference and the only thing I can't decide on is how to tackle the loader and ergo situation. I guess with the LS I can always build a dirt ramp or something if needed when loading into a dumpster or small dump truck. Here is a thread showing the height difference, post #26 http://www.tractorbynet.com/forums/...-xr4040c-owners-3.html?highlight=any+xr+3037c the user mentions a longer loader lift cylinder which I wonder if that can be done without messing up anything that could be in the way. But the does seem like the overall length loader is shorter compared to the one in the pic.
Thanks
Brian
/ Help Me Decide Narrowed Down to LS or Kioti #2
From what I have read & experienced LS & Kioti both make very nice tractors.My experience is from owning 2 Kioti tractors one open station one Cab model.Both have operated flawless.I am sure both LS & Kioti would serve you well.
/ Help Me Decide Narrowed Down to LS or Kioti #3
How often will you be needing a dump truck to load into? With the money saved by getting the LS you could get a dump trailer and not have to worry about lift height.
/ Help Me Decide Narrowed Down to LS or Kioti #4
Exactly my initial thoughts.
/ Help Me Decide Narrowed Down to LS or Kioti #5
Maybe look at some other comparisons?
How does the subframe for BH FEL compare between the two in attachment, ground clearance, removal etc.
Welds and machining
Routing of hoses and type/placement of hydraulic controls
Access for general maintenance
Good luck on purchase decision, but once delivered...happy day
/ Help Me Decide Narrowed Down to LS or Kioti #6
That's a hard choice. They are both good tractors. Some other members have mentions the lower lift height of the LS vs. the Kioti also. One of them ended up with a Massey. That was how he solved his dilemma. You just have to figure out what is more important to you. Good luck with it.
/ Help Me Decide Narrowed Down to LS or Kioti #7
A higher loader is nice, but like these guys said, how often will you be loading a dump truck? I can't speak for the other pros and cons, but I will say that the auto-PTO shouldn't be much of a big deal. Honestly, I am very glad that my tractor doesn't have that feature. Under NO circumstances do I want my PTO coming on automatically! The lever is easy to reach. When I want it on, I'll turn it on.
/ Help Me Decide Narrowed Down to LS or Kioti #8
I agree, all these automatic things are nice when-if you do this stuff all day every day, but for the occasional user, just seems better to know for sure when & what is going and if it's automatic then that goes away. I will say that I think that there is a choice of either auto or manual settings though.
One last thing, depending on if you need-want other implements, but the savings that could be had getting the LS would get you there much faster. A tough decision that's for sure.
Good luck to the OP. ;)
/ Help Me Decide Narrowed Down to LS or Kioti #9
I have never used the Auto PTO setting on my Kioti. The point of it is that when you are running a tiller and come to the end of a row and lift the 3pt lever to make your turn the PTO shuts off. And when you drop the 3pt to lower the tiller, the PTO turns back on again. I don't have a tiller so the feature has been useless to me. It is nothing more than a micro switch set to be hit by the 3pt lift lever. You could add Auto PTO to your LS with a little work and wiring. It is no big deal to add it to any electrically engaged PTO.
/ Help Me Decide Narrowed Down to LS or Kioti #10
How high is a dumpster?
How often would you need to load a dump truck?
How high would any dump truck you might possibly purchase be?
How high would a dump trailer that you would use the savings to buy be?
Could you use the dump trailer to also haul the tractor if you wanted to?
Would it be affective using a high dump truck to haul the tractor?
Do you realize how much more cost effective it is to have a dump trailer opposed to a dump truck for most home use?
How often would you actually be loading a dump truck that you would find to be too high?
Have you actually measured the height of any smaller dump trucks?
As far as the AUTO - PTO is concerned its a feature I will probably never use and couldn't be concerned if it was there or not (over 2years with mine now and still haven't used it once). Its also a feature I never needed or wished I had on any of my other machines
PTO Switch placement isn't really a factor for me and I honestly cant see the placement of a simple on off switch being important unless it was somehow in a place where it could be easy to bump it accidentally For most I would assume it isn't a switch that is used nearly as hard as the loader joystick or a gearshift and would not even consider having to reach up to turn it on or off as a concern. Type and placement of other things would take my attention much more and the placement of the PTO switch would be last on my list if it was even a consideration at all.
/ Help Me Decide Narrowed Down to LS or Kioti #11
I would think that if all you did was PTO implement work, that the location would be of some importance, other wise I agree with you, wouldn't make much difference.
/ Help Me Decide Narrowed Down to LS or Kioti #12
I think you'll be very happy with either tractor. I also think you'll never regret having more HP or hydraulic power.
I'll bet there are many who wish they had to deal with the tough choice you have to make.:laughing:
Let us know how it turns out. With pictures.
/ Help Me Decide Narrowed Down to LS or Kioti #13
Well, you're talking about two of my favorite tractor brands here. Either way you get a good tractor. I went with LS because I got a great price, then used the savings to upgrade my mowers, which get a lot of use. I will admit though, that the lift height of the fel comes into play about 2 or 3 times a year when storing seldom used items on a rack in the barn
As for how tall the dumpster, dump truck etc. I don't know. I'm not buying or own any of these they will just be used at random while my house is being built and who knows later on. For pto work I would say my work would be an average amount.
rgr33, if you had the kioti would the height still be an issue? Specs only show it about a foot difference but looking at the pics in the link even though it's not a kioti you can see a pretty big difference in height.
/ Help Me Decide Narrowed Down to LS or Kioti #15
No organization audits nor certifies the performance claims made by tractor manufacturers.
Further, some tractor manufactures promote FEL specs with the loader bucket, some without the bucket. It is difficult to figure out which does which.
Rather than make yourself crazy with this minutia, go with the dealer who you feel most in tune with and who has the best reputation for service. Should this dealer be within ten miles of where you expect to operate the tractor you are a lucky person and will be a happy operator.
That may be the case, however in this instance we actually have pics showing the loader height difference and it's pretty substantial. Whether it is 5k substantial and the other items I do not know. That's why I'm here. As for dealers, I feel comfortable with both so that is a wash.
/ Help Me Decide Narrowed Down to LS or Kioti #17
You understand the comparison in post #26 that you refer to is between an LS and a Massey, right? The 4th picture that has 3 different tractors, the center tractor is a Kubota.
Yes but all their loader height spces are roughly 105" + which also what the kioti(108") is. I wasn't comparing it to the massey just showing what most others in this class of tractor are compared to the LS.
/ Help Me Decide Narrowed Down to LS or Kioti #19
Yes but all their loader height spces are 100" + which also what the kioti(108") is. I wasn't comparing it to the massey just showing what most others in this class of tractor are compared to the LS.
OK. This apparently is a big concern of yours, so as it seems to me, the LS should be removed from the list and you get the Kioti, all is well other than the cost is more. Stretched out over time, not that big of a deal.
Good luck with your decision.
/ Help Me Decide Narrowed Down to LS or Kioti #20
Loader specs aside, are the dealers you are shopping worthy of your business?
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Chevrolet 2500 Flat bed (A61307)
Chevrolet 2500...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2004 Ford Explorer SUV (A61569)
2004 Ford Explorer...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A60736)
2019 INTERNATIONAL...
