Ratchet rake
/ Ratchet rake #1
widefat
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
I'm looking at a Ratchet Rake for my L3200 - but it appears that my bucket (LA524, 58") falls between the 52" size and 68" size.
For RR users - what size are you using?
TIA
/ Ratchet rake #2
TIA
I don't know the lenght but my is exceeding both ends by an inche or two and i am very happy with it. Between too short and too longer i'd choose the latter.
/ Ratchet rake #3
Why not get the longer one and cut it to match loader?
/ Ratchet rake
That's not a bad idea - I wonder what the dimensions of the tie points are? For the 68" rake, the manufacturer site shows 54" to ..what?
The outer edge, center, or inner edge of the strap? If inner edge,the tie points may not fit inside the bucket. If outer, probably, if center, maybe.
Maybe I'l give them a call and ask.
/ Ratchet rake #5
If you call, why not ask Ratchet Rake to cut you the attachment exactly the width of your bucket?
/ Ratchet rake #7
I use mine on my skidsteer and let it hang over a few inches. 72" rake on 66" bucket. When I use it on my TLB it's a little short on the 84" bucket. Never had any problems with it either way as long as the tie downs will fit.
/ Ratchet rake
I finally got around to ordering a 52". It was delivered a couple of days after I placed the order - FAST!
So far so good - I am learning how to use it, but it looks promising as far as being worth the investment.
/ Ratchet rake #9
For me it's worth the investment. I've got a lot of hours used on mine and the paint is barely scuffed just at the tips. It takes a pretty good piece of steel to hold up to a 74 hp backhoe. It's definitely my go to tool to remove brush and briars.
NorTrac Rake (A64127)
(6) 250 Gal Chemical Totes (A64127)
(6) 250 Gal...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
