Any suggestions would be greatly appreciated.  Craig
Craig,
I would guess it's a combination of things, low screen brightness, maybe poor camera automatic exposure control, etc.
I have a system, sold on Amazon, from
Backup Camera System | Rear View Backup Camera | RearViewSafety.com
My tractor has a cab, and that's a major plus, I think, in keeping direct sunlight off the screen. Even so, and with no additional sunshade over the smaller built in one that came on the display, I've never had an issue with screen visibility. That said, when using the bucket or forks to pick up something in the shade when facing the sun, the front camera exposure control puts the object of my desire (hmmm:c) in the dark - you're facing the sun, so your eyes naturally adjust, the monitor is just fine, but the silly camera keeps you from seeing anything! Fortunately, that doesn't happen all that often.
An earlier version of my front mount - since modified to lower camera height, using a larger thinwall tube (1" vs 3/4") with a forward curvature (instead of straight version shown). The larger tube dimension so allow camera plug to fit through tubing to exit at bottom. Bottom fitting clamps onto cross tube and is adjustable with hand nut.
A closeup of the front cam mount bracket showing how the clamp works for fore and aft positioning as well as allowing height adjustment - this is nice when changing to forks or when needed to move cam out of the way as when charging into brush :d):
